Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 12-20-2004, 10:53 PM
1990crx 1990crx is offline
accelerator problems
My friend has a 1965 Impala. He says that when he hits the accelerator, it stays accelerated. He says it's the spring. Is that hard to change?
Old 12-22-2004, 09:33 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
Re: accelerator problems
It is incredibly easy to change.
I'm assuming that "the spring" he is refering to is the one that is attached to the throttle linkage and keeps it closed when there is no pressure applied. All you have to do is remove the air cleaner and the spring will be obvious (unless it's missing). If replacing the spring doesn't solve the problem, then it's probably a vacuum leak.
Old 12-22-2004, 09:50 PM
public's Avatar
public public is offline
Either way it is a .99 cent repair. Good Luck.
Yes, I am retarded.
