Old 12-20-2004, 09:24 PM
eyespy eyespy is offline
No high on fan control
Hopefully someone can help here I have a 1995 Lumina apv,on the control panel I can turn the heater fan on low ,medium,and the fan works as soon as I put it on high it shuts off,weird and really sucks when its -30 does anyone have any suggestions...thanks in advance
Old 12-22-2004, 01:04 AM
mlw35405 mlw35405 is offline
Re:Lumina No Fan on Hi
My Lumina (car) did the same thing. I lived with it for 6 months before I finally figured out that the HI fan setting has a separate fuse that was blown. Check that first. I think the fuses are HVAC 1 and HVAC 2. Hope this helps, if not, then there is a relay under the dash that is probably bad.
Old 12-22-2004, 10:57 PM
Thanx I'll check that didn't think there might be two fuses hope your right because that would be a fast fix,thanks again and Merry Christmas
Nope one fuse guess I'll keep checking for other options
Old 12-24-2004, 02:43 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: No high on fan control
Did you look in the underhood power distribution block?
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
