Old 12-20-2004, 07:55 PM
Integrity1's Avatar
Integrity1 Integrity1 is offline
Unhappy Blue smoke?
2 the point. I have a 1991 civic dx w/ D15b7. whenever i dive large clouds of bluish white smoke comes out. i hear a ticking noise under the hood. i just got new spark plugs and all of them turned black. one even had oil on it! could some 1 tell me what it might be? i thought a bent valve, but would a bent valve make all the spark plugs turn black? oor that much smoke? i need help please!
Look what I can do!
Old 12-20-2004, 07:58 PM
383Chevelle 383Chevelle is offline
Banned
if there was oil on the plug and ur car is pretty old, think about checking the rings, oil is leaking through them?
Old 12-20-2004, 08:01 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Blue smoke?
Blue smoke is oil burning. Sounds like your rings are worn out, needs new valve seals, possable bent valve/valves need adjusting, maby bent rod, a whole lot of things could be wrong.
Old 12-20-2004, 08:03 PM
Banned
ya its kinda of hard to tell what exactly is the problem but it sounds like the oil problem is pretty extensive if oil was on the plugs...did u check ur oil lvl? how much have u lost? if its not that much u can try going to a thicker oil which might solve the problem
Old 12-20-2004, 09:01 PM
Integrity1's Avatar
Re: Blue smoke?
i havent lost any oil but i changed the oil with 10W40.
Look what I can do!
Old 12-20-2004, 09:07 PM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
Re: Re: Blue smoke?
mine used to blue smoke on my d15b7 with 200,000 miles on it,
not all the time,but certain times it would shoot out a big puff of blue smoke,fog up the road,
I had a compression test done on it,
it come to be the #1 cylinder,burnt ring,
it got bad,oil began to come out of the intake,oil everywhere,
qtz & qtz day after day,
it soon wouldnt bairly start,I had to set the idel at 2000 rpm just to drive,so it wouldnt die,
I considered the motor blew up,
do a compression test on it,
& hope its a burnt valve,unless you want a swap newayz.
In the process of B00stin my D
Old 12-21-2004, 02:20 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: Blue smoke?
if there is white smoke accompanied by a sweet sugar smell...it could be a headgasket problem as well. Does it overheat?
Well, it sounds to me like you need a new motor. Just go pick up a used one for 100-200 bucks. They're barely worth that even.
The work your motor needs is not worth it.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 12-22-2004, 07:33 PM
Re: Re: Blue smoke?
is your oil on both the top & bottom of the spark plug?
