Old 12-20-2004, 06:36 PM
mrfirebird mrfirebird is offline
cold start idle
i've got a 94 blazer code W.
do these trucks have a fast idle on a cold start?
i've got a rough idle when cold and the rpms seem to be the same as when it's warmed up. idle gets smooth when warmed up.
rpm's don't change at all.
Old 12-21-2004, 12:45 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: cold start idle
Done a tuneup lately?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-21-2004, 06:30 AM
yep it's got all new stuff in it, it'll burn the 31's off.
when it's a cold start idle is ruff but if you apply abit of gas it smooths out. any ideas ?
Old 12-21-2004, 03:18 PM
BlazerLT's Avatar
AF -Advisor
Re: cold start idle
What did the tuneup contain?
What was replaced?
Old 12-21-2004, 06:55 PM
Re: cold start idle
plugs,wires,cap,rtr button.
Old 12-21-2004, 07:03 PM
BlazerLT's Avatar
AF -Advisor
Re: cold start idle
What about the fuel filter, air filter, PCV valve, Idle air control valve cleaning?
Old 12-22-2004, 06:52 AM
Re: Re: cold start idle
yep, all that except the air idler control valve. where and what does it look like. i have a chiltons book , but i'm at work at the moment.
Old 12-22-2004, 12:07 PM
BlazerLT's Avatar
AF -Advisor
Re: cold start idle
it is a small device right above the intake butterfly.
Remove, clean with TB cleaner and a toothbrush, rinse with TB cleaner again and reinstall.
Then reset your computer, start your truck and allow it to idle till warm, then put it in gear with the brake pressed and do not move and allow the engine to relearn its idle.
