Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 12-20-2004, 06:13 PM
wickedboost wickedboost is offline
What do i need for a d16z6 custom turbo setup
I'm planning to make a turbo setup for a d16z6 (1.6i 16v sohc vtec)
Turbo: T3/T4 (saab (very common here in nl) or other, volvo)
Manifold: new @ shop
Wastegate: new @ shop
Downpipe: new @ shop
FMU: Vortech 12:1 ( what's the 'missing link' some ppl r talkin about on other forums?)
FMIC: shop
BOV: HKS or other
All needed piping/hardware is in stock.
7psi is fine for me btw.
Am I missing something?
Thx in advance!!!
Old 12-20-2004, 08:24 PM
97CivicX's Avatar
97CivicX 97CivicX is offline
Send a message via AIM to 97CivicX
Re: What do i need for d15b7 custom turbo setup
missing an intercooler. ditch the FMU and get some sort of electronic fuel management (afc, uberdata, hondata, emanage...etc...)
D16Y7/D16Y8 mini-me swap
turbo coming this summer
Old 12-21-2004, 01:17 AM
Already had it, FMIC = Front Mounted InterCooler Btw, a stand alone fuel management system is kinda out of my budget. That's why I took that FMU as an alternative. Why should i drop it? Isn't it possible to use it anyway? 6/7psi is fine with me, if that has something to do with it.
Old 12-21-2004, 01:58 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
honda engines dont run on positive manifold pressure. your ecu will throw a CEL if it senses positive pressure from the MAP sensor. the missing link check valve (air can only go one way with this) prevents the map sensor from seeing positive pressure.
http://www.synapseengineering.com/ML001.html
you pretty much have all the basic hardware to get it going besides the oil lines and accessories (turbo timer, catch can, boost controller, etc). theres alot more details to get into, but, it seems like you just want to get it up and running.
you'd be more happier and safer with someway to control your fuel. afc with dsm injectors are effective and better than an fmu, but, an fmu will work.
GL, let us know how you come out. Just remember, do it right the first time
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-21-2004, 04:45 PM
97CivicX's Avatar
my bad, missed that. as for the fmu, it should be fine for 6-7 psi but not really any more than that, so itll be more money later on if you wanna up the boost. plus an safc can be had for under 200, well worth it if you want cheap(er), more reliable tuning.
