Old 12-20-2004, 05:59 PM
spriggan0072 spriggan0072 is offline
Send a message via AIM to spriggan0072 Send a message via MSN to spriggan0072 Send a message via Yahoo to spriggan0072
New HP after Port and Polish
My '94 SL went to the shop and i'm getting my upper and lower intake manifolds, heads, throttle body ported and polished. with this alone, what kind of HP are we talking about? i don't think i'll break 250, oh and i might throw some headers on, but i'm not sure what kind yet. but with just the port work alone, what HP am i looking at?
Old 12-20-2004, 10:15 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: New HP after Port and Polish
I bet you feel it pull a bit harder farther into the RPMs. Who knows about power, it depends on how the job is done and your other mods.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 12-21-2004, 02:58 PM
Kev3000GT Kev3000GT is offline
I'm gonna do the same thing. I don't know about HP, but it can't hurt to port, especially with high miles.
Old 12-24-2004, 12:45 PM
well, i saw the port work yesterday, oh my god, this guy should have charged me another 300 for it. my throttle body is like paper thin now. couple of friends told me that the motor should be putting out something like 280HP so i'm gonna be getting like 250HP to the wheels i think. i'm gonna try and get some pics, the before and after shots look like concrete vs glass.
Old 12-25-2004, 12:43 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
i'm gonna be the first to call BS on this one. you're hoping to put down 250 Whp from just a port job? i'd like to see some before and after shots. also, there's much talk about the flow characteristics of our cars already being quite optimal. Do you have a VR4 or NA? What other, if any, mods do you have? If you even THINK you might be pushing 250 whp <cough, cough> then watch out you don't run it lean with all that extra air in there!
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-25-2004, 12:52 AM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
a lot of cars have put out 60 extra ponies from a port job, of course some less and maybe some more.
though i've never seen the dyno sheet my buddy said he gained 30 something to the wheels from a port and polish
i've heard many people say it does wonders. but i dont know first hand, only what i've heard so.......
Old 12-25-2004, 01:24 AM
stfuad's Avatar
stfuad stfuad is offline
Send a message via AIM to stfuad
Why would he run lean? Between the MAF and o2 sensors the ECU should adjust.
Old 12-25-2004, 01:29 AM
Linebckr49's Avatar
Re: Re: New HP after Port and Polish
for one thing, the MAS is before the intake plenum (where the porting job was done) and should really not have much, if any, effect on the porting job, unfortunately. he could use to upgrade to a larger MAF like that from a Camaro or something.
secondly, the O2 sensors won't do crap, unless he has a wideband O2
93 3000GT base
Old 12-27-2004, 10:31 AM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
Is timming really that sesitive? I figured all those people out there who p&p would get discouraged if it where so complicated.
06 GTO: SLP Longtubes, SLP Loudmouth II K&N intake,
Ported Intake Manifold,
Ported Throttle body, MAF screen delete.
Tunned by Jeremy Formato. 381whp, 376wtq.
07 Ion Redline: Bone stock w/ factory Competition package.
In response to a race my wife had while pregnant with our baby:
Originally Posted by jeepgclwj
Prediction.... I bet we will hear about a guy down in Miami thats the King of street racing in about 18 years...Way to get him started....
Old 12-28-2004, 05:03 PM
Igovert500's Avatar
blue + red light magnet
spriggan, would it be possible for you to do a dyno run? I think it would be quite beneficial for our knowledge and for others contemplating doing this to their NAs if we had some solid numbers to look over.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-28-2004, 07:51 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
Re: Re: Re: New HP after Port and Polish
also, just to add. i dont know what the stock fuel injectors are rated on the SL's but with 250whp, you might be getting into your fuel injectors maximum flow rate, which would make your car run lean. 250whp is somewhere in the range of 295-325bhp....so thats like gaining 100bhp from a port job...not gonna happen....but im with these guys. i wish you the best and try and get it on a dyno to see what kind of gains you got!!!
ZedEx Crew Member #4
Old 12-29-2004, 01:52 AM
sLADe781 sLADe781 is offline
How does polishing something increase hp?
Old 12-29-2004, 02:02 AM
Z Cars Fanatic
porting and polishing the inside of an object enables air to move at a greater velocity and volume....polishing something good ables things to move across it easier. take a bowling lane for example....if it wasnt waxed the ball wouldnt slide across it at such a fast rate, more friction = less speed...same applies with air in your engine, the less friction the faster the air will move, which will allow more air to flow through the engine. i think that should help...
Old 12-29-2004, 02:12 AM
Yeah, that makes sense. Hehe Thanks.
