Old 12-20-2004, 05:43 PM
rick_b_48185's Avatar
rick_b_48185 rick_b_48185 is offline
Banned
Send a message via Yahoo to rick_b_48185
Sticking Tailgate
The tailgate is sticking...we have tried greasing it but it's NOT working. Wondering if anyone has any suggestions on how we can fix the tailgate ourselves. Thank you.
Old 12-20-2004, 09:08 PM
skipr skipr is offline
Check the striker plates (on each side) I have seen them bend in too much and it hangs up the latch mechanism. Very easy to fix, get some channellocks and bend it back.
Old 12-20-2004, 11:59 PM
Banned
Re: Sticking Tailgate
It's not actually sticking shut It's not closing. The mechanism that closes around the post is stuck. I sprayed them with penetrating oil, then put on some lithium grease. Still seems to be not closing. Wondering if I need to change the cables?
Just a little post script. This truck which I just bought is already nickel and dimeing me to death. Only had it 3 months, already have had to replace the 4x4 switch, rear window, passenger side mirror, now maybe cables in the tailgate. What a pain in the ass! Chevy needs to put better quality stuff on thier trucks. Not sure I'll ever buy another one!
Old 12-21-2004, 10:43 AM
You got that right! I have been nickel and dimed to no end. Door handles(two interior, two exterior) at $76 ea., hood release lever, tailgate cables,...etc. It's like the metal they r using is some kind of die cast crap they use to make childrens toys.
Old 12-21-2004, 11:48 AM
mjgjr72 mjgjr72 is offline
try lubing the handle abbembly, there are too levers behind the handle on a pivot point, if they do not release fully the latches can not lock see other post
http://www.automotiveforums.com/vbul...d.php?t=334819
Old 12-21-2004, 12:20 PM
Banned
Re: Re: Sticking Tailgate
Yep it worked. Thanks. Hope they don't do that every time it gets cold outside.
Old 12-21-2004, 12:49 PM
your welcome, don't think it is the cold, just that lovely car killer called corrosion, a quick shot of lube every once in a while should keep it from happening again
