Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-20-2004, 05:13 PM
tinkermania tinkermania is offline
passenger door lock stuck in lock also makes loud noise when hit auto lock
The passenger back door on my 2000 JGC makes a loud noise when i hit the lock it sounds like it's coming from inside the door. Lock is stuck in lock position and will not open. Any ideas???????
Old 12-20-2004, 05:44 PM
JDPascal JDPascal is offline
Re: passenger door lock stuck in lock also makes loud noise when hit auto lock
The rod from the lock solenoid to the lock lever may have fallen off. You will have to remove the door trim to check for sure.
There is a clip that holds the rod in place.
JD
Old 12-29-2004, 01:40 PM
nez_fer nez_fer is offline
Talking Loud noise
I have a 99 Grand and it was making a sound like a goose everytime I used the power locks. It was the right rear passenger door. It eventually siezed, but still made the noise. I went to the auto wrecker and got the "Power door lock actuator" and replaced it. Very easy to do, but you need the correct size torques bit.
Good Luck.
