Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 12-20-2004, 05:03 PM
kerdon kerdon is offline
How to get key cover off of steering column.?
Im replacing my heater core but i cant get the damn starter key cover off so i can take off the top panel.
Help anyone?
Brute force?
Old 12-20-2004, 06:16 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Re: How to get key cover off of steering column.?
Should be 3 screws on the under side.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 12-20-2004, 11:54 PM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
if its like a 96, then theres up to 6 screws, (I think mine has 6), then you also have to remove the key cylinder because it goes in over that cover. theres a button on the bottom of it that you should press with something like a screwdriver, and then slide it out.
Old 12-21-2004, 05:15 PM
97Bird's Avatar
97Bird 97Bird is offline
Remove the tilt wheel handle and shank by unscrewing it. Rotate the ignition switch to the RUN position and using a 1/8 inch drift punch, press the lock cylinder retaining pin through the access hole in the cover. Then remove the lock cylinder and four scews in the lower cover.
