Old 12-20-2004, 04:00 PM
justlearning justlearning is offline
Send a message via AIM to justlearning
switch
does anyone know how to hook up the fan switch i bought a 30 amp relay and a 30 amp switch dont even know if thats enough but im not sure what wire to run from the fan to the relay, or do i run the wire from the fan to the switch???? what do i do just take and splice the power wire on the connector and run it off of that????????
Old 12-20-2004, 08:22 PM
96CamaroSS's Avatar
96CamaroSS 96CamaroSS is offline
Re: switch
Well lets see relay's usually have 4 wires. Batt power in, 12 volt out, switch lead in, and a ground.
_______
12v from battery -----------/ R /
12v to fan-----------------/ E /
From switch---------------/ L /
Ground-------------------/ A /
-------------------------/ Y /
Old 12-20-2004, 08:48 PM
Re: switch
yeah i know how to set up the relay what i dont know is if that 30 amp will be enough and more importantly what to connect the 12 volt out to like i said do i just splice into the connector to the fan motor or what
Old 12-20-2004, 10:28 PM
96CamaroSS's Avatar
Re: Re: switch
30 amps should be plenty. You can probably splice in the wires for the fan. Do you plan on having just the switch operate the fans or both switched and computer controlled ?
Old 12-20-2004, 10:55 PM
Re: switch
well the only aspect of my computer that controls them is the air conditioner or heat ive replaced everything dealing w/ the cooling fan (relay, motor, temp sensor, etc..) the previous owner has butchered the wiring so at the moment i dont feel like tracking it down although i will but i would like the switch i just got through searching past posts and noticed one sayin i could just use my present relay and splice the orange wire goin to it and run that to the switch, then run a power and ground to the switch...is this true cause if so ill keep the relay i bought for another project im plannin
Old 12-21-2004, 02:11 PM
Re: switch
come on now ive seen plenty of peoples cars on car domain that have them i know someone in here must have put one in id like to try and do it today since its been about 20 degrees outside lately and today its like 40 and i have no garage so wether is a factor
Old 12-26-2004, 09:46 AM
NINÅ's Avatar
NINÅ NINÅ is offline
Fan-tastic Wiring
Well it's a busy time of the year, lots of clients parties, etc. so this is probably too late for good weather but here is your answer.
As they told you a 30 amp relay is enuff.
1. Connect one end of your fan switch to a 12V source.
2. Connect the other end to one end of the relay coil.
3. Connect the other end of the relay coil to ground.
4. Connect one end of the relay contact to the battery positive.
5. Connect the other end of the relay contact to the fan positive.
6. Use 20 amp fuses to protect the wiring.
You're all set!
(In my cars I used blue LEDS to indicate ON {optional})
REFUSE
. . TO . . LOSE
