Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 12-20-2004, 03:10 PM
anthony90si anthony90si is offline
86 runner power steering problems
hi guys i noticed there is water in the power steering and i wanted to know how to drain the oil. is there a plug?? and where. it cold out lol.
thanks guys
Old 12-20-2004, 08:23 PM
4Wheel's Avatar
4Wheel 4Wheel is offline
AF - Advisor
No drain plug
There is no drain plug but there is a "return" line to the side of the reservoir. Disconnect it and attach a tube to a jug and flush the system since water will sink that's about the best way to purge the system.
Don't let it run dry just keep adding fluid as you turn the steering wheel.
Careful you will be dealing with a lot of fluid real fast!
Next time you POWER WASH that engine compartment cover that cap with a bag.
Good luck
Old 12-20-2004, 08:26 PM
Re: 86 runner power steering problems
k thanks i will try that. but everthing is soo thick. all frozen.. its liek -25 out
Old 12-20-2004, 08:46 PM
4Wheel's Avatar
AF - Advisor
Not good
That's even worse if that water in the PS system is not antifreeze!
Toyota sells rebuild kits for the pump does not include the bearings tho.
