Old 12-20-2004, 02:50 PM
tsipsi20 tsipsi20 is offline
Send a message via AIM to tsipsi20
boost leak or ignition problem?
I'm not sure if i have a boost leak or if it's an iginition problem or what but I can be just driving lightly, (maybe 1/4 throttle?) and my stock and autometer boost guage will start to creep up until i hit maximum boost (10 pounds - for winter anyway) and it'll run really shitty like it has no power at all, and as soon as i let off the gas all i hear is PSSHH! from the blow off valve, kinda like i should be moving somewhere. Then i'll get pissed off, slam on the gas, say five minutes later, and there it is, full boost and full power. My car then begins to lunge with no problems. This happens all the time, moreso when it's cold, but really at any moment. When it does, my car jerks and loses power. But like i said, it only happens sometimes, other times it'll boost up perfectly. I have a mitsu 16g turbo, if that helps for any reason. Can anyone help me diagnose the problem? I kinda feel like if it were a leak, it would do it all the time. HELP!
Old 12-21-2004, 02:48 AM
coolguycooz coolguycooz is offline
Sounds like maybe your having a really bad misfire? or fuel? check your plus make sure there like isnt oil in all of them or something not sure.
96 RS 5 spd.(Daily Driver and ex Ricer "I am ashamed of it")
98 GSX 5 spd. (Currently stock, spending all my mod money on body work.)
Old 12-21-2004, 09:26 AM
I replaced the coil pack last year so i don't think it's that, and just replaced the plugs a few weeks ago. The only thing it could be is the plug wires... that is to say that it's even an ignition issue? But would it boost sometimes, and then not?
Old 12-21-2004, 10:36 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: boost leak or ignition problem?
You either got a boost leak or your car is severly out of timing. Get a timing light and play with your CAS, make sure its 5* BTDC!
Old 12-22-2004, 01:17 PM
Angry
i doubt it's timing... cause my car was be severely fucked up upon everyday driving. It only does this sometimes. Just the times it happens are always the worst. Just when you think you're about to lunge on 5.0 ...
BUT on another note, what are altima quarter mile times? I raced one on the highway last night, i couldn't pull on him, and this was quite upsetting. But he couldn't pull on me either, so at least we can't call it defeat. I know right now, given my mods and boost i'm running that i'm probably only running mid 14's. Given i'm only running 9-10 pounds for winter i'm not that upset. But i still should have smoked his triflin' ass! Shut down at 115 w/ no pull on either side.
1990 Eagle Talon TSI AWD
MOD LIST:
______________________
Mitsubishi s16g, Turboback 2 1/2 in. w/ Hi-Flow Cat, ACT 2600 Clutch, K&N Filter, Taylor 10.5 mm Spark Plug Wires, BPR7ES Plugs, Dejon Tool UICP, Turbo XS Type H BOV, Samborskey Shift Kit, Walbro 255lph, Injector Clinic 550's, 2g mas, Vaccum line elimination, SAFC II, Pocketlogger, 17" Motegi Gloss Black Rims, VIS Carbon Fiber Hood, Eibach Lowering Springs, KYB AGX, Homemade boost controller, Autometer Boost/Air Fuel
Old 12-22-2004, 01:27 PM
EclipseRST's Avatar
Banned
Check timing! It's always a good thing to check, I'm sure the timing belt is on good but your ignition timing seems to be off.
SEARCH
I have a hard time believing an altima runs lower than a 15!
Old 12-22-2004, 01:43 PM
kjewer1 kjewer1 is offline
AF - Advisor
When you replaced the plugs, what did you gap them to?
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 12-22-2004, 04:22 PM
When i replaced the plugs, i didn't gap them. I know you're supposed to gap them at .30, but i was in a rush and just threw them in. Now that you mention it, would it make that big of a difference? Besides, i never gapped my plugs and i've never had these problems. It didn't start happening 'til lately, and i figured if that wasn't the problem... ?
MOD LIST:
Old 12-22-2004, 11:51 PM
EclipseRST's Avatar
Banned
There is most likely your problem! The boost is blowing out the spark. Take them back out and gap them, you should always check the gap before puting them in. The gap should be around .28-.30
Old 12-23-2004, 12:19 AM
Also the wires could make you missfire just a thought you said wires might not be it they could be. Inspect your wires and check to see if they have any white cracks or bubles forming in them or something like that it could be the cause.
Old 12-23-2004, 09:18 AM
AF - Advisor
My car is a little different because of the boost and airflow levels, but the point is still valid. The car works great at 026, but wont run at 028. I'd say it make a difference For normal cars, jakes suggestion is balls on. These plugs are mostly used in NT cars and come gapped closer to 040-045 in most cases. And they vary too, you want them all to at least be the same! Gap those bastards, and tell us if it worked.
Edit> Even BRAND NEW wires can misfire on a turbo car. I've seen almost every major brand of parts store/redneck wire fail on install. NGKs are even more amzing when you look at them in this light, they always work. Magnacores are popular, but I can't get a set that doesnt misfire... One of the biggest mistakes people make is to say "I put in a new xxxxx, it can't be that."
Kevin Jewer
Old 12-23-2004, 12:54 PM
Also this could happen be careful. You gap your plugs then dont just drop them in, because dropping them in could dent it and change the gap. Take your finger and kind of slide it in along the edge with the plug, so you dont dent it in and mess up the gap.
Old 12-24-2004, 11:06 AM
AF - Advisor
Thats a good tip. And anytime you drop a plug on the floor/ground it has to be checked over carefully and regapped. They will always fall heavy end first
Kevin Jewer
Old 12-26-2004, 09:44 AM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
well looks like i need to check my plugs now too because i have a problem very simlilar to this....thought it was a boost leak, but when i checked for leaks, i couldn't find any...the problem i'll have is, when i try hitting boost in 3rd-4th gear, it will start to boost, then my car gets real jerky and it seems like i should be hauling ass when i'm not, then when i let off the throttle, it's louder than all hell...could having an extremely small amount of shaft play cause this in a T25? Also, i do have aftermarket wires...Thundervolt 10.4mm, but i have had this problem before the wire upgrade...
Old 12-26-2004, 02:04 PM
TreeFrog's Avatar
TreeFrog TreeFrog is offline
Send a message via AIM to TreeFrog
a 2005 Alitma se-r runs a 1/4 mile in 14.2 and a 0-60 in 5.5. http://modernracer.com/nissanaltimaser.html
Something new is coming...
