Old 12-20-2004, 01:29 PM
Mike W. Mike W. is offline
Tranny
I have a 1994 chevy pick-up with a 700 R-4 The trans. likes to slip into passing gear at almost any speed. It does this erradicately, also I live in Minnesota, it is below freezing temps here now and I didn't have this problem last summer when it was warm. I had the local Gemini repair shop do a complete flush and fill of the tranny. It didn't help any. What can I do?
Old 12-20-2004, 07:20 PM
Jeremy-WI Jeremy-WI is offline
Re: Tranny
I'd put in a new fuel filter first, and if that doesn't have any change have someone check out the throttle position sensor. FYI, if your vehicle has the original tranny it is a 4L60E, basically an electronic controlled 700r4
Old 12-30-2004, 11:11 PM
troy1 troy1 is offline
AF -Advisor
Re: Tranny
to be correct you have 4L60E what do you mean it slips into passing gear?
Old 12-31-2004, 12:56 AM
Ape0r Ape0r is offline
Send a message via AIM to Ape0r
Re: Tranny
troy: I'd assume he means it is downshifting.
I'd start where Jeremy said to.
Old 12-31-2004, 02:48 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: Tranny
Fluid and filter change (get it power flushed, if you don't you are wasting your time and money) If this doesn't help have the sensors checked and then if all else fails take it to a trans shop. My 700r4 does the same thing. It has on every tranny if have had in the 88. This is my third trans by the way.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 02-28-2005, 12:04 AM
Re: Re: Tranny
Well, I've tried just about every sensor one can replace. My next and last step is the computer. Thanks for your help (ALL) and I'll check back here later to see if any-one else has had the same problems and been able to find a solution.
Mike W.
Old 03-02-2005, 10:08 AM
99redsilverado's Avatar
99redsilverado 99redsilverado is offline
just go ahead and bite the bullet and buy a trannsmission. by passing gear, i assume you mean from od(4th) to 3rd. OD is electronic, if you lost that, id say check sensors. 2nd 3rd, and reverse, however are hydraulic, you have internal failure.
