Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-20-2004, 12:28 PM
george536's Avatar
george536 george536 is offline
Unhappy Starting problems.
Ok yesterday i wanted to start my car when it seemed liike it wanted to turn on you can hear it and the lights on the dash (like the srs,oil,etc)were turnin on (like blinking dimly) and the car wouldnt turn on. Untill i gave it gas right when i turned the key. then it would start up. it did this to me twice now and it only does it when the car has een sitting out for a long while like overnight. Is my battery going dead or is it something else?
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 01-16-2005, 01:50 AM
plateinum plateinum is offline
Banned
maybe its the fuel injection
you might want to see if your fuel injection is dirty what kind of octane do you put in.
Old 01-16-2005, 03:51 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: maybe its the fuel injection
Use punctuation and gammar or your posts will be deleted. Also, put your car in your sig.
Read the rules... Cause you obviously didnt do that!
