Old 12-20-2004, 01:06 PM
decaturforlife01 decaturforlife01 is offline
Info on hook up remote starter on 99 tahoe
I have a 99 tahoe and i just got the hornet 563t remote starter. I just need little more help
Old 12-21-2004, 12:07 PM
Re: Info on hook up remote starter on 99 tahoe
How to find the right wire on the ing block. I have 2 wire that have 12v when the key isn't on. How to find the start wire
Old 01-05-2005, 09:08 PM
Racincc85's Avatar
Racincc85 Racincc85 is offline
Send a message via AIM to Racincc85
go to www.the12volt.com. They have all sorts of really good wiring diagrams
Old 01-05-2005, 11:37 PM
Andy Dorsett Andy Dorsett is offline
GAS / DIESEL 1998-1999
WIRE COLORS LOCATION
12 VOLTS CONSTANT RED IGNITION SWITCH HARNESS
IGNITION 1 PINK (+) IGNITION SWITCH HARNESS
IGNITION 2 WHITE (+) IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER ORANGE (+) IGNITION SWITCH HARNESS
STARTER YELLOW (+) IGNITION SWITCH HARNESS
PARKING LIGHTS (+) BROWN at the HEADLIGHT SWITCH or LOW in DRIVERS KICK PANEL
DOME LIGHT PURPLE (-) at the HEADLIGHT SWITCH
DOME LIGHT SUPERVISION WHITE (-) at the HEADLIGHT SWITCH
POWER DOOR LOCK LIGHT BLUE in EITHER DOOR HARNESS See NOTE *
POWER DOOR UNLOCK WHITE in EITHER DOOR HARNESS See NOTE *
TRUNK/HATCH RELEASE BLACK/WHITE or WHITE at RELEASE SWITCH See NOTE **
TACH SENSOR WHITE at the ECM See NOTE ***
DIESEL WAIT to START DARK BLUE (-) at the INSTRUMENT CLUSTER
BRAKE
WHITE (+) at the SWITCH ABOVE BRAKE PEDAL
HORN
BLACK (-) at the STEERING COLUMN HARNESS
FACTORY ANTI-THEFT PASSLOCK II Requires part #791 bypass module
NOTE * If vehicle is a 4-Door, the Door Locks are a TYPE "A", on the 2-Door the Door Locks are a TYPE "C".
NOTE ** If vehicle is equipped with the REAR LIFT WINDOW it is a (+) POSITIVE release, with the CARGO DOORS it is a 5-wire system and requires a relay.
NOTE *** The ECM (Electronic Control Module) is located on the DRIVER SIDE inner fender. The TACH wire is in a BLACK plug marked "WHITE".
This is from http://www.bulldogsecurity.com/
