| Off-Topic Talk about anything other than cars. |
re-using 7bolt parts on 6 bolt engine
when i bought my 6bolt shortblock i knew i had to buy a few things. and make some modifications for it to fit in my 96 gsx. i was wondering what i could use on my existing 7bolt to save me some $. can i use the oil pan, oil filter bracket, oil cooler, oil screen, harness assembly's, oil pressure gauge, pulley's, things of that nature from my 7bolt if their in good shape? im mainly talking about external bolt on parts for the sortblock. thanks..
DSM geek |
can i use the oil pan,yes and no, the second gen has a smaller oil screen.
oil filter bracket, no it has a different bolt pattern. oil cooler, yes but why use the oil to coolant when it would be better to go oil to air. oil screen, I wouldnt the because first gen is better. harness assembly's, what parts? oil pressure gauge, yes if you use the sending unit. pulley's, I would suggest doing this. It is a ribbed vs v belt thing. I like the ribbed. youll need some of the water pressure and temp sensors, a first gen radiator, a good wiring diagram of both the first and second gen motor, a heater hose T fitting to splice your MAP to the brake booster and a few more hours of time. do you have the first gen or second gen coilpacks? you need the 1g mounting bracket atleast. check vfaq. theres too much to write here and it would take too long. big tip though, Modify the timing tin before trying to put it on and use the 2g timing side motor mount, and your time an patience. thats a big part of the swap, TIME AND PATIENCE.
Who needs speed when you push 155.8 dB.... I do!!! |
Re: re-using 7bolt parts on 6 bolt engine
so what "can" i use from my 7bolt to save $
DSM geek |
You can use is the motor mount with modification (must use 1st gen timing components = idler pully) You can use all the pullys, water pumps are the same, if you get a 90 oil filter housing, you will need a 90 water pipe. If you have a 91-99 oil filter housing you will need a 90-94 (unless you have a 2g head) water pipe because of the oil to water oil cooler. The oil pressure sending until is the same, they just screw in.
alternator, powersteering pump, MAP sensor ( this has to be tapped into the brake booster vacuume line), turbo if its a upgrade, timing side motor mount, wiring harness with mods for the CAS, fuel rail, you can use the coilpack but mounting is a pain, uicp and make sure that you have the right water neck
Note: You do not need to hook up the map sensor. It will not throw a code nor affect your motor in any way.
Thanks eclipse rst. I did not know that....
im a little confuesed with what your trying to relay.
quote: "You can use is the motor mount with modification (must use 1st gen timing components = idler pully) You can use all the pullys." I'll be using a 1g head.. Quote: "If you have a 91-99 oil filter housing you will need a 90-94 (unless you have a 2g head) water pipe because of the oil to water oil cooler. The oil pressure sending until is the same, they just screw in." Q: is it a possable to convert/fabricate oil/water to oil/air using the 91-99 oil filter housing and 90-94 water pipe? i think a better question was "what won't fit/work/interchange". im beginning to think im in alittle over my head with this winter project. i'll try and make better sence of this all later when i have more time. Reviewing.. Will work: all pullies, except idle pully?(1st q)?; oil cooler, oil pan, oil pressure gauge and sending unit, motor mounts, o2 pump, oil filter housing. alternator, powersteering pump, wiring harness (with modification), crankshaft angle sensor, hydrolic tensioner, arm? (what the hell is an arm tensioner?) & T-belt tensioner,entire fuel delevery system. upper & lower timming covers.. Not sure: crankshaft pully, ignition system, Evap controle system, thermestat, tranny bolts, oil screen (are you 100% sure 1g is better?) cruise control, ABS, fans, o2's, exhaust Manny, o2 husing, downpipe, dejontools uicp, Maf, fuse box , knock sensors Will Not work: Oil filter bracket, radiator, hoses, map. are we on the same page here, anything else? Thanks guys http://www.roadraceengineering.com/2...torinstall.htm
DSM geek Last edited by scottsee; 12-21-2004 at 02:44 PM. |
Re: Re: re-using 7bolt parts on 6 bolt engine
7 bolt oil pan will not work. 7 bolt oil filter housing will not work. You can not use the crank sensor (6 bolts use the cam sensor). What is O2 pump? (Do you mean oil pump? If so a 7 bolt oil pump will not work, the crank case covers are different!) 7 bolt idle pully for the timing belt and arm tensioner that it's mounted on will not work. 7 bolt lower timing belt cover will not work. Quote:
Also you can use the radiator and hoses still. |
ok. RRE's website says: "2nd gen. ECU's require a crank angle sensor"
http://www.roadraceengineering.com/2...torinstall.htm also the list of modified usable parts that they recomend are diffrent from the ones listed above. is there a website with a better compiled documentry on 1g engine swap and part requirments? becasue the website info just isnt easly available, beyond that, there just isnt anyone around here in this town who can help me out, and im tearing my hair out trying go gather what information i need to do this properlly.
DSM geek |
Well I'm not sure if these write-ups are any better than RRE's, but I'm sure they cover other/additional information that may be useful to you.
Magnus 6-bolt swap info: http://www.magnusmotorsports.com/article_1g2g.htm VFAQ oil cooler info (thought this may explain some things about the oil cooler differences): http://www.vfaq.com/mods/oilcool.html
![]() 95 GSX DSMlink, "50 Trim", and track times coming VERY SOON!
Yes the 2nd gen ECU requires a crank angle sensor but on a 6 bolt there is no were to mount it... So therefor you can not use it. What you do is run the wire that goes to the crank sensor to the cam sensor like the 1st gens do.
Trust me, I know what I am talking about. I have done so many of these swaps I could do it in my sleep now! Its what I do for a living right now... Build 6 bolts and install them in 1st gens, 2nd gens, and Galant VR-4s. |
when you fall asleep tonight, please feel free to float over.
i think i could have asked my origional question in such a more effecent way!! please, jake, if you were doing this swap yourself, what parts would you order?? i have "NO" 1g parts, only the shortblock with internals, ballance shaft removal kit, could you add what i have missed, i would really like to close out this thread and continue with this project. 1g part list 1G CAS 1G (90) Oil Cooler 1G oil pan 1G Oil Pump/Front Case/Filter housing 1G (90) Water Pump 1G (90) Water Pipe 1G lower radiator hose 1G Thermostat housing/ Water Neck 1G tensioner arm 1G T-belt Covers
DSM geek |
1g oil screen
You can reuse the stock radiator hose and water pump if you want... There is no difference between the pumps unless you want a brand new one (not a must but good idea.) Oh yea... You also need: ![]() 1g 6 bolt Block 1g Head and Intake manifold |
so im good to go with what was listed on the 1g parts + oil screen, and just reuse all the 2g parts from my 7 bolt?
DSM geek |
