Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 12-20-2004, 11:33 AM
timmyx1 timmyx1 is offline
240sx brake quests
i have been searching around for the conversion parts needed for a 5 lug conversion. well i found replacement hubs with no modifications needed to anything.
my problem is i have a sponsorship from a company that gives me a good discount on brembo brakes systems.
i cant seem to figure out what parts i need. i know i need a 5 X 114 rotor but then i cant seem to figure out what really gonna fit.
also getting the right calipers are in question too.
i already know im gonna have to replace all brake lines with i wanted to do in the first place for safety and performance reasons.
when it comes to fitting on brakes for this conversion i am a nub and i could really use some help.
btw i have on order 17x9.5 rays gramlights 57s so i need something that will fit in those wheels another perk of sponsorship
Old 12-20-2004, 12:55 PM
logik23's Avatar
logik23 logik23 is offline
Banned
Send a message via MSN to logik23
Re: 240sx brake quests
I'm pretty sure S14 5 lug brakes will fit an S13 with a 5 lug conversion.
Old 12-20-2004, 06:25 PM
so the calipers would mount? probably the bigest problem i have is getting the proper calipers to mount right the rotors are easy to find
Old 12-20-2004, 06:32 PM
logik23's Avatar
Banned
Get 4 lug S13 calipers and 5 lug S14 rotors.
Old 12-20-2004, 06:33 PM
Chuki_breath Chuki_breath is offline
why not just get a system thats made for a japanese 180sx???? they should fit, im sure they have an aplication for them. Really its not that hard. why not ask your sponser, id hope they would have a clue about something. With those rims any brake kit will clear so i wouldnt worry. Really depends on how much stopping power your going to need, and if your going to be road racing and what not.
Old 12-20-2004, 06:35 PM
logik23's Avatar
Banned
180s are 5 lug?
Old 12-20-2004, 06:49 PM
yes if i remember, but since hes going to be doing the conversion it wont make a difference, thats why i said just get a kit made for a 180.
Old 12-20-2004, 08:26 PM
TatII TatII is offline
just get a brembo kit for 4 lug 180sx's. this will save you trouble for the 5 lug swap. also when you go with larger rotors, you need to put caliper extending brackets. a brembo kit will come with that along with all the hardware included it even comes with steel braided lines, and the rotors are usually a 2 piece unit.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 12-20-2004, 08:46 PM
logik23's Avatar
Banned
But 5 lug is better, mor rims and looks better.
Old 12-21-2004, 10:42 AM
yes also the wheels i want i can only get the correct size in 5 lug but thanks to every one with thier help
Old 12-21-2004, 03:15 PM
D-Bo's Avatar
D-Bo D-Bo is offline
get the z32 4-piston calipers, with steel braded lines. thats probably the most efficient setup for the 240 cause you can get the most expensive part in good used condition.. i have them on the front (don't really need them on the back) and they're amazing.. all i need is something to increase the pressure (i don't know enough about braking systems so i don't know what part to get). once i get that, i'll use the pads, rotors and lines i have now and replace them when the time comes
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 12-21-2004, 04:04 PM
logik23's Avatar
Banned
Get a 300ZX master cylinder.
Old 12-21-2004, 04:12 PM
D-Bo's Avatar
is that all it is?? just the master cylinder? i think i heard something about a pressure somethingorother..
Old 12-21-2004, 09:17 PM
pressure thingy your talkin about is called the proportioning valve. what it does is that it sets a split point for the brake pressure going from the front to the rear.
in other words, it reduces the brake pressure goin to the rear disc because when you brake, the weight is shifted off the rear to the front, so the rear would lock up. by putting a different proportioning valve, it will reduce the rear brakes to the proper pressure.
this is why your rear brakes lock up first when you do the Z32 brake swap. by swapping in the Z master cylinder, it will include the correct proportioning valve to let your brakes work properly. i have a Z32 master cylinder installed on my ride.
damn i had to pull out hte text book for this cause i haven't needed to touch on this subject in years!!
94 Acura NSX
Best E.T. 13.559
Old 12-21-2004, 09:31 PM
i wouldnt mind having a copy of your text book lol sounds good and informative. And actually you can get more rims than you think in four lug also, im going to sport the 4 lug, y change if you dont have too you know what im saying. I mean good companies make 4 lug rims that fit our rides....example advan's: super advan vers. 2
