Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 12-20-2004, 11:10 AM
86FieroGT 86FieroGT is offline
Question Help w/ window guide... things
Hey, I have another dilemma. While I have my door skin(s) off to replace the hinges, how do I go about changing the "felt" window spacer stabilizer guide pad things?
I'm speaking of the ones of which there are 2 per door on the inside surface of the glass. You know what I'm talking about
Any guides, FAQs, pictures are welcome. Thanks again.
Old 01-31-2005, 11:22 AM
84fiero123's Avatar
84fiero123 84fiero123 is offline
Re: Help w/ window guide... things
first of all why did you pull the skins off to replace hinge? could have done that by removing door pad or is that what you ment? as far as window guide felt try weather stripping at locall hardware store, if you use the felt kind and double faced tape you can do it yourself without a kit. not sure who would carry kit for that. you could try kick hill
http://www.kickhill.com/mechelec.html
Old 01-31-2005, 12:14 PM
FierceGT's Avatar
FierceGT FierceGT is offline
Send a message via MSN to FierceGT
You may still be able to purchase those through your local GM/Pontiac dealer. The Fierostore sells them for 5.95 each, but I still recommend you check your local dealer first....they will probably save you a few bucks if they have them.
