Old 12-20-2004, 10:57 AM
a0breaker a0breaker is offline
Check engine light and slow peddle response
My '88 CRX starts up just fine, but if its cold it idles at like 3000-3500 sometimes, which is really unsettling. (Goes back to normal once warm) But thats not the direct problem.(i think) After going a mile or so my check engine light comes on and the gas peddle has a delay from the time i push it to when the engine revs. Usually, you push the gas, the rpms increase right away, but after the light comes on, it takes almost a second for the car to react to me pushing the gas. Any suggestions on what could be causing this and how to fix it?
Old 12-20-2004, 11:45 AM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Re: Check engine light and slow peddle response
what ecu code are you getting?
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 12-20-2004, 12:46 PM
It flashes 7,14,7,14, etc.
Old 12-20-2004, 03:29 PM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
I would say whatever it is,is all the same problem,
I mean,
the idel will stay up to 3000 rpm when started cold,
maybe giving more gas,
& your also having problems with the gas pedal responding,
have you tried to give it gas from under the hood?
maybe see if its responding as quik,it could be the accelerator cable,
check the codes on what they mean,
I believe TSC just posted some up,
its definitly a fuel problem.
In the process of B00stin my D
Old 12-20-2004, 03:50 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
code 7 would be throttle angle, 14 would be electronic air control. Sounds like something in your throttle body is going screwy.
Old 12-20-2004, 11:35 PM
Thanks guys, ill give those suggestions a try. I was thinking it may be something to do with a sensor. Doesnt seem like theres anything mechanically wrong.
