Old 12-20-2004, 10:18 AM
1992eclipseGS 1992eclipseGS is offline
Doors Frozen shut... help!
Both my car doors are frozen shut.. Anyone got any suggestions?? I climbed thru the Hatch and tried to open them from the inside but it didn't work.. My next suggestion was to just start the car and let it run for a while, but i don't wanna do all that if its not gonna work... i don't know if will heat up the car enough. Don't wanna have to climb back thru the Hatch to turn off the car.... I'm 5'11 and 220 lbs.. climbing into a 92 eclipse isn't easy... Some suggestions??
1998 RS
5 speed, Stock front bumper w/molded urethane lip, Blitz side skirts, Bomex rear, JSP Carbon Fiber hood. Halo Projection Headlights, Escort radar detector, Turbo style spoiler, 1,200 watt sound system with 2 dual 12 subs, 20% executive tint, 17" sport rims, Custom built 2 1/2 Exhaust, OBX 4-1 Header, CAI, KYB GR-2 struts, Sprint lowering springs.
Old 12-20-2004, 11:39 AM
GSTRacerNVUS GSTRacerNVUS is offline
Re: Doors Frozen shut... help!
Hairdryer and extension cord? I've never lived anywhere where it's gotten that cold, but I've heard of people using a hairdryer.
97 Eclipse GST MT
Race Every Day Like It Will Be Your Last.
My one insignificant mod: Dump Tube - CUT
Old 12-20-2004, 11:44 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Hot water on the doorjams.
Kris
2012 Genesis Coupe 2.0t
Old 12-20-2004, 12:23 PM
viet_boiiiii's Avatar
viet_boiiiii viet_boiiiii is offline
Send a message via AIM to viet_boiiiii
breathe on your door handles?
new 2006 Scion tC - 5spd
-magnaflow catback
http://www.cardomain.com/ride/2088489
~~~R.I.P (7-2-05)~~~
1998 Eclipse Gst - 5 spd
Old 12-20-2004, 01:34 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
yeah man i live in boston and its freezing here that happened to me this morning,i had to keep bumping up against the door to break it free,,hahaha bad new england
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 12-20-2004, 01:40 PM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
yeah, we got light rain then it froze this morning in MN. Road sucks and a nice layer or ice on everything.
Pictures of the Truck
Old 12-20-2004, 02:12 PM
Friend from up north said to use De-icer. It's almost like alcohol and just melts the ice. You pour it all the way around the door jam. You can find it at K-mart. I also heard windsheild washing fluid works too.
97 Eclipse GST MT
Old 12-20-2004, 03:03 PM
Black97GST Black97GST is offline
yeah hot water or a hair dryer would work but what if the water freezes and its still in the door?? wont u have the same problem when u try to get out?? probably wouldnt happen but i would be a little cautious. it is 1 degree here today! its sooooo cold and my car hates the cold!
Old 12-20-2004, 04:10 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
thank god for Southern Cali, we dont get that cold of whether hear, but the hot water should work.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 12-20-2004, 04:34 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
i live in wisconsin andi i dont have a problem with door freezing... the problem that i have is the key hole, i put the key in and that sucker wont turn , some times it twists my key before i get the door un locked... i found a new method of turning the key back and forth to beak the ice...works nice..
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 12-20-2004, 05:03 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
use washer fluid or deicer. 97-3clipse you can get little spray cans of deicer with nozzles to jam into the lock to melt the ice. or you can try pouring washer fluid into a really small funnel aimed into the lock lol jk
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-20-2004, 05:07 PM
pro3racer pro3racer is offline
Yeah, i live in wisconsin too, my car gets the garage for the nights, but when i'm at work, i find my doors lightly frozen, i need to use some force, but its not a problem. I also have a lot of problems with my key not turning, but my passenger side is better, so i always unlock my door on the passenger side, then walk around and open the drivers side door(power locks, hehe). I bought some de-icer, but haven't been able to use it yet.
1991 Eagle Talon ESI, manual, 2.0 FWD
1992 Eagle Talon TSI, manual, 2.0 FWD
Old 12-20-2004, 05:31 PM
NCTotalEclipse NCTotalEclipse is offline
Send a message via AIM to NCTotalEclipse
Hot water freezes faster than cold water, so don't do this until you're ready to go. Don't walk away. Get the door open, then dry the area off.
Old 12-20-2004, 06:37 PM
Nayr747's Avatar
Nayr747 Nayr747 is offline
Huh?
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
Old 12-20-2004, 06:42 PM
Re: Re: Doors Frozen shut... help!
Originally Posted by Nayr747
Huh?
really, it does. You never learned that 1 in high school science? Put cold water in a cup and hot water in a cup. Put them both in the freezer. Check like every 10 minutes or some junk. The hot water freezes faster b/c it makes steam or something.
