Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 12-20-2004, 09:23 AM
JeffD JeffD is offline
90 Olds 98 - Engine quitting
I recently replaced the Ignition Module and Coil Pack on my Olds 98 w/ 3.8L V6. The car will start fine but after it has warmed up it will just die. If I let it set for a few minutes it will start but die a few minutes later. Any thoughts?
Old 04-10-2005, 05:27 PM
jloomis jloomis is offline
Re: 90 Olds 98 - Engine quitting
I'm having the same problem with my 1990 98 olds? did you ever fix your problem? What was it? Thanks Jim L.
Old 04-10-2005, 08:59 PM
gggman gggman is offline
Re: Re: 90 Olds 98 - Engine quitting
I have a 1991 98" with electronic everything.I have a different problem now,but had to deal with your same problem recently.On your firewall you have several relays( along the top) ,get a new one and hopscotch down the row while it is in the no run condition and you will probably find your problem.Its about a $ 5 or $6 dollar relay .15 years old under a hot hood and they do go bad. Just a suggestion its fairly cheap to check it out.
Old 04-12-2005, 10:03 AM
chevelleman chevelleman is offline
Send a message via AIM to chevelleman Send a message via MSN to chevelleman
you might want to have your crankshaft position sensor checked out i have seen it many times where it will run fine and then just die and wont start until it has sat for awhile i would say there is a pretty good chance of it being your crank sensor as they are fairly common to let go in their old age
Old 04-25-2005, 08:56 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
Where is the Crankshaft Position Sensor on this model, and what kind of a job is it to replace?
Old 04-26-2005, 09:25 AM
The sensor is behind the harmonic balancer,(main pulley on crankshaft).If you take your right front tire off and remove the inner fender panel(just plastic snaps)it is a lot easier to get to.You will need to get a spacer tool to get the new sensor set just right as you only have a few thousands of clearance and it is very very hard to see. gggman
Old 04-26-2005, 08:06 PM
kmohr3's Avatar
Re: Re: Re: 90 Olds 98 - Engine quitting
Thanks gggman, have you ever replaced one? Do I need to pull the harmonic balancer off? Can I do the job without the special tool? Any other advice??
Old 05-04-2005, 11:28 AM
Re: Re: Re: Re: 90 Olds 98 - Engine quitting
You probably can do it without the tool,if you measure very carefully where the sensor is at.It was easier for me to remove the pulley because I had never replaced one before.Wanted to see what made it tick.DO NOT TIGHTEN THE SENSOR MOUNTING BOLT TOO TIGHT,I DID,BROKE THE BRACKET. Good luck!!
