Old 12-20-2004, 08:57 AM
russ61 russ61 is offline
hard cold starting
My 94 blazer won't start when it gets below 30 degrees. A shot of starting fluid and it starts right up(fuel).Whats been done ,complete tune up plugs ,wires cap ,rotor.Fuel pressure regulator now52 psi was 38psi.replaced leaking lines in intake.Has good spark ,the starting fluid makes me think it's fuel related.But what?? Runs great once it starts.
Thanks Russ
Old 12-20-2004, 09:17 AM
Mikado14 Mikado14 is offline
Re: hard cold starting
Thanks Russ
Fuel pressure is low, looks like it is pump time.
Old 12-21-2004, 01:01 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Whoa whoa bro, he said he only replaced the FRP and it came up.
What about the fuel filter, ever changed?
I would open up the upper plenum again and look for washing.
Only installing the side FPR leads to the unit failing again.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-21-2004, 04:38 AM
Yes fuel filter has been replaced along with temp sensor.Is 52 lbs enough for cold weather starting??Abook I have says 38-42,another book says 48-52,other posts here say 58-60.I'm sooo confused.
Old 12-21-2004, 05:01 AM
BlazerLT's Avatar
AF -Advisor
CPI Blazers require 56-64 psi to work properly.
I would check your battery voltage output with the engine not started.
Should be in the 13.4v range.
