Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 12-20-2004, 08:26 AM
kymagred kymagred is offline
Unhappy 1994 Transmission
Need some help. I'm losing trans fluid and see no leak under the Explorer. Can transmission fluid get into the radiator? Transmission fluid looks ok, the coolent looks like it has something in it. Thanks T
Old 12-20-2004, 09:48 AM
molehole's Avatar
molehole molehole is offline
Send a message via AIM to molehole
Re: 1994 Transmission
First thing to check is the vacuum modulator. When the modulator goes it will burn transmission fluid through the exhaust. I went through the same problem with my 94. Your coolant might need to be changed. When was the last time it was done? With winter approaching get your Explorer in top running condition. You will thank it later.
Good Luck
Old 12-20-2004, 10:30 PM
I have only had the 94 for a few months. The coolant checks ok, just looks like something is in with it. I will change it out on my off day, on midnights right.
