Old 12-20-2004, 03:14 AM
jbruns29 jbruns29 is offline
IAC valve reset procedures
I have a 94 K1500 that has a idling problem,Ive tracked everthing down to the IAC,does anybody know what the reset procedure is for the computer after you install a new IAC.The truck idles fine(600)untill I drive a block or so then the idle will raise to about 9-1200 rpm's,if I shut the truck off the idle goes back to normal, I don't know if the reset sequence is keeping this thing from idling right,ive replaced the temp sensor and all other sensorscheck out good egr,tps ect...
Old 12-20-2004, 04:28 AM
mtndw mtndw is offline
You never mentioned if you checked for vaccum leaks or not. Most often these are a source of idle snags. Also another thing to look at is your throttle body gasket .As for reseting your computer, all you need to do is disconnect your battery for a few minutes (key turned off), then after you reconnect it ,take the truck for a drive . While driving the ecm relearns the sensor values & begins to do it's thing after that.
Hope that is of some help...
Old 12-20-2004, 10:14 PM
Re: IAC valve reset procedures
Thanks for your help
