Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-20-2004, 02:23 AM
FoRCedInDuKsionGsT FoRCedInDuKsionGsT is offline
Unhappy Too much BoOst...HELP!!!
Alright i finally got the boost up and it seems to be boosting properly, but its boosting more than i thought. For some reason when the boost hits 10psi it just suddenly jumps up to 16psi out of nowhere in less than a sec. I was like holy crap!!! so i let off the throttle. I have a JoeP MBC and it is set to 0 so i dont know why im boositing so high if my BC is not even adjusted for more boost. Any of you guys have any idea how to get the boost down? Im only trying to hit 12-13psi on full throttle cause i dont wanna mess things up. Help me out, Thanks!
Here's what i got under the hood:
-Free mods
-Greddy Type-S BOV
-JoeP MBC
-K&N filter
-full 2.5" custom cat-back exhaust
-16g turbo
*keep in mind i have a stock fuel system
Old 12-20-2004, 07:27 PM
1Fast_Tsi's Avatar
1Fast_Tsi 1Fast_Tsi is offline
Re: Too much BoOst...HELP!!!
the bc could be hooked up wrong, but im not sure, who hooked it up, you or a shop?
Red 90 tsi AWD 5speed
Love KIllin those V8's!!!!!!
Check me out at www.cardomain.com/id/1fast_tsi
Old 12-20-2004, 08:41 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
does it just spike to 16 or does it stay at 16? did you take out your BCS at the same time? 15-16 isnt uncommon for it to spike to with the free mods and a mbc. also try replacing all your boost control hoses and wastegate hoses with braided fuel line. the fuel line will make the MBC respond faster since the hoses wont stretch and expand when they get pressurized
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-20-2004, 11:37 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Port your O2 housing and you'll be fine, you are getting boost creep. 2.5" exhaust and a stock O2 housing are a bad combo with a 16g! I had the same problem on my GST, except my boost creep was up to 24psi. Make the boost controller vacuum lines as short as possible while still being able to mount it somewhere. This will make the WG open as fast as possible with a MBC.
Old 12-21-2004, 01:05 PM
reply...
I installed the mbc myself...vac line from bottom of mbc T'd from BOV vac and other vac line to wastegate actuator...This is right isn't it?
It doesn't stay at 16psi, it just jumps to 16 when it hits 10psi on full throttle in less than a second. I believe it would be spiking to 16psi.
port the 02 housing??? That's the same as the turbo outlet pipe right? Just a different name i guess?
BTW thanks fellas on your inputs...
Old 12-27-2004, 06:27 PM
POWERGOD POWERGOD is offline
I have a mbc also and mine jumps all the way to 23 and then back down to 15 and stays, is this bad? It is a stock turbo
Old 12-27-2004, 07:48 PM
powergod: that is boost spike. try your mbc/wastegate hoses with braided fuel line from napa. also try and keep the lines as short as possible.
-1stGenRocks-
