Old 12-20-2004, 12:12 AM
00blackzx3 00blackzx3 is offline
Turbo PSI Talk...
Ok guys im curious here, at what psi do the stock vr4s run at? I have heard you can tune these turbo systems to run at a different psi? So these stock turbos can run up to 15 psi safely? And in order to run the stock turbo system up to 15 psi what modifications would l need , or can i just tune these turbos straight to 15 psi? Also i have another question.... Can you hear the purge of the turbo when on the throttle with an exhaust installed? Also, can you install some sort of purge system to the turbo to hear that sweet sound while shifting?
Old 12-20-2004, 01:22 AM
viet_boiiiii's Avatar
viet_boiiiii viet_boiiiii is offline
Send a message via AIM to viet_boiiiii
Re: Turbo PSI Talk...
ok i can answer some..
first off i dont know about vr4 stock psi or anything about their limits..
for your other questions.. 1) the "purge sound" u are talking about on throttle is called turbo Spooling up. Or do u mean that Pssshhhtt sound? if so, thats the blow off valve. u can hear the turbo spooling sound better if: 1) your windows r down or 2) sun roof slide back 3)both
What the hell do u mean installing purge system? thats nos right there right? u want to hear the pssht while u shift gears? well u gota get to a good amount of rpm to hear that sound when shifting cause the higher rpm u get to and shift ... the louder it is.
new 2006 Scion tC - 5spd
-magnaflow catback
http://www.cardomain.com/ride/2088489
~~~R.I.P (7-2-05)~~~
1998 Eclipse Gst - 5 spd
Old 12-20-2004, 01:28 AM
sorry for the confusion... rookie to the turbo world. But yes i didnt mean purge system i guess. I want the pssshhh sound so i need a blow off valve. i dont care about turbo spool or whatever, i just want taht psshhh sound LOUD as can be
Old 12-20-2004, 01:36 AM
Well if u have turbo u need a bov (blow off valve) and intercooler and more parts. IF u have turbo why the hell r u running it without a bov? What car do u have ? a focus or a 3000gt? Well my suggestion is to get an aftermarket bov.. most likely a HKS, Greddy, XS, etc. Depends on what sound u want.
-magnaflow catback
Old 12-20-2004, 01:46 AM
nah man, i am selling my focus in 2 days and gettin a local vr4. i just want to load that psshh sound into it as soon as i get it. i see i have to put an after market bov in ?
Old 12-20-2004, 01:52 AM
mike93vr4's Avatar
mike93vr4 mike93vr4 is offline
yes stock is not that loud
Old 12-20-2004, 08:02 AM
G35turbo G35turbo is offline
Ok stock 91 to 93 is 9psi,and from 94 to 99 is 12psi. That is stock psi. You should not go over 12psi before u got Intake, Down-pipe. And defentily a Boost gauge because the stock one sucks. then you can go on 14psi. But you should not go over 14psi with out any bigger injectors, fuel pump, and a Air/fuel controller. If you go to 3si.org and click on Mods on the left and then click on STAGED PERFORMANCE UPGRADES.
If you want to get some sound you can go get the Turbo XS BOV that is the loudest you can get.
I heard that u should not go over 15psi with stock turbos.
Old 12-20-2004, 08:07 AM
You can go to www.mvpmotorsports.com , 3sxperformance.com and some other websites for performance parts. I am ordering mine from a local store and My car is a 97 vr4, I am getttin a Act Heavy duty street clutch, intake, TopSpeed Down-pipe, Turbo XS boost controller, Boost Gauge, Boost Pod, Turbo XS BOV, and also gutted out my Pre-Cats. That should be little over 400hp I hope.
Old 12-20-2004, 04:11 PM
Igovert500's Avatar
blue + red light magnet
This is why we have an FAQ. Prior to purchasing mods in the dark...save your money for a bit, and read the FAQ, so you know what you are doing...otherwise you inevitably will run into problems and waste money...
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-21-2004, 09:47 PM
read it, had more questions.... i hate when people just say read the faq... i read the thing and just had some more questions.
Old 12-21-2004, 09:49 PM
lol, i feel u. lol lol
Old 12-22-2004, 12:27 AM
Alaa 3000GT Alaa 3000GT is offline
Send a message via MSN to Alaa 3000GT
If you have enough money buy a good blow off vavle and drag exhaust system ..
Don't buy any exhaust with bad specifications ..
A big single muffler is good for performance because the gases of the engine will get out faster than if it's subordinated ..
Wanna see Examples ?
That one made for performance
it does weigh 4.5 kilogram while this one is made for the show and the performance . It weighs 12kg
I see a lot of owner of 3si buying a dual exhaust systems !
I don't know why but I think it's probably the price ..
Old 12-22-2004, 02:04 AM
GritMaster GritMaster is offline
Because the cars have dual exhaust systems stock, And it looks nicer
RIP Andy "Hypsi87" Filson... We'll miss ya mate
Originally Posted by nissanstreetz
For about 700 dollars you can have about 80 horespower at the wheels and about 70 torque.
Old 12-22-2004, 02:14 AM
These dual exhaust systems are not stock and honestly it does look nicer !
This is a picture of 3000GT 91 with stock exhaust system
Old 12-22-2004, 02:35 AM
Yep, And that's a dual Exhaust
all i meant is stock they have a dual exhaust system, not that one in particular
