Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 12-19-2004, 09:50 PM
paliagp paliagp is offline
Tranny talk!
hey,
i have a 90 teg rs and converting it to standard, now should i go for a stock tranny or something else?any suggestions?? thanks!
Old 12-19-2004, 10:15 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Tranny talk!
Stock cable B series tranny
Old 12-19-2004, 10:22 PM
Re: Tranny talk!
thanks
Old 12-19-2004, 10:25 PM
whtteg's Avatar
Re: Tranny talk!
You will also need to get the pedal assembly, tranny mounts, clutch cable and shift linkage and a shifter. Not sure about the center console, I know that the 94+ you can just change a plastic trim piece.
Old 12-20-2004, 11:19 AM
Re: Tranny talk!
here are the parts i need to gather, am i missing anything........
manual tranny
manual ecu
shift linkage
intermediate shaft for manual tranny
clutch,brake,gas pedal assembly
clutch master cylinder
clutch reservoir
clutch slave cylinder
hydro clutch lines
shift knob
shift boot
Thanks!!
Old 12-20-2004, 11:31 AM
whtteg's Avatar
Re: Re: Tranny talk!
manual tranny
manual ecu
shift linkage
clutch reservoir
hydro clutch lines
shift knob
shift boot
Thanks!!
No no man. You need:
Manual Cable clutch B series tranny
Manual ECU
Shift linkage
Intermediate shaft for manual 90 integra
Clutch,brake,gas pedal assembly
Clutch cable
Flywheel for a Manual tranny motor
Shifter and shift knob
And possibly the center consoule trim, like I said above not sure about the trim pieces on the 90-93.
Old 12-20-2004, 11:54 AM
Re: Tranny talk!
ok ill search for these parts and let you know if i find then,,,,,thanks!
