trans issue!!!!
k got a 4 spd in my hatch n when i go on the highway in third it kicks outa gear, n then i couldent downshift commin off the exit i had to roll to a stop to mgo into first n move again the i was sittin at the light n car wouldent go n i tried to get it to go into any gear was stuck in neutral...now this morin it worked again...what happen? trans done...or is the clutch system fucked? jus got it n the guy put in a exteddy stage 2 clutch...
Re: trans issue!!!!
Does is grind when you try and put it in gear, or does it just not go? Make sure you clutch system is working fine, if it is, might be the tranny starting to go out.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete) www.naytontech.com :: youtube.com/naytontech |
Re: trans issue!!!!
in my hf crx i had about a year back it had a problem of throwing it out of gear when I was in 2nd. still drove fine, just wasnt able to downshift 2nd unless you held it in real hard. I was told it was my synchros, I didnt care and I drove it like that until i sold it.
Saturn Stealership Technician #331 |
if the car jups out gear into neutral,particularly when decelerating or going down hills,first check the shift lever and internal gearshift linkage. excessive clearance between gears and the input shaft or badly worn bearings can cause jumping out of gear. other internal tranny parts to inspect are the clutch pilot bearing,gear teeth,shift forks,shift rails,and springs. could also be bad 3-4 syncro. try double clutching when downshifting to put less stress on syncros
91 Hatch SI Heart of my Baby - DOHC ZC - Si tranny - PG7 Finally painted!!!
i tryed double clutching n that dident work either but the biggest thing was i couldent get the car to move when i was stopped in 1st went to take off-nothin, then it jumped foward almost like droppin the clutch at idle n i hear a noise in the trans in neutral like a throw out bearing but intermittant...
