Old 12-19-2004, 06:53 PM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
Adjusting Amp
I am trying to get the most bass out of my subs without damaging them. Here are the specks for both the amp and subs. Would I tune the bass boost, Low pass filter... etc
Performance Teknique ICBM 782
2 Channel Bridgeable Power Amplifier
2000W MAX @ 2 ohm
Power Output
350W x 2Ch @ 2 ohm
250W x 2ch @ 4 ohm
700W x 1Ch Bridged
23dB/OCT Crossover Slope
Variable Subsonic Filter (10Hz-100Hz)
Variable Low Pass Filter (30Hz-500Hz)
Variable High Pass Filter (50Hz-1KHz)
Variable 18dB Bass Boost
High & Low Level Input Through RCA
Double Sided PCB
Dual Protection (Thermal & Short Circuit)
RCA Line Out
Power & Diagnostic Led Indicator
2 Ohm Stable
Soft Delayed Power on
Tri Mode Capability
MTX Thunder 4000
Nominal Power Handling 200 Watt
Size 10"
Miscellaneous
MPN t410x3
Product ID 36871
UPC 1544235036
Mounting
Mounting Diameter / Length 9.06 In.
Top Mounting Depth 9.81 In.
Power
Power Handling 400W (Peak)
Technical Features
Frequency Respond 39 Hz - 150 Hz
Impedance 4 ohm
Peak Power Handling 400 Watt
Sensitivity 88 dB
White 07 STI, Bone stock for now
Old 12-19-2004, 07:01 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Adjusting Amp
bass boost off, lowpass filter around 80, gain set properly (there are walkthroughs all over the place), each sub wired separately to the individual channels, or the subs wired in series and bridge the amp.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 12-22-2004, 07:57 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
I sometimes use the amps bass EQ .... just have to be careful
