Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 12-19-2004, 06:38 PM
rsmith1997 rsmith1997 is offline
Send a message via Yahoo to rsmith1997
Question 1997 jimmy questions
I just got a used jimmy and i don't have a manual
can any one answer these questions
1. is the 4x4 shift on the fly
2.how do i tell what suspenion I have I herd there is 2 kinds
3.is there any kind of factory security I will be adding after market.
thanks to all that help
and sorry if I offended anyone for asking for a cd radio I saw tires for sale and that it was ok. I know better now.
Old 01-07-2005, 01:20 PM
Bob Shaw Bob Shaw is offline
97 Jimmy
You can shift into or out of 2 Hi and 4 Hi only. You need to stop for 4 low. I think there was a ZR2 suspension which has some of the full size blazer parts.
Bob Shaw
Old 01-08-2005, 11:20 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 1997 jimmy questions
2hi and 4 hi on the fly. Just don't be accelerating when you switch them back and forth.
4lo has to be engaged while in neutral at a full stop.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-09-2005, 11:59 AM
goinbig goinbig is offline
Send a message via AIM to goinbig
Went you shift between 4hi and 2hi, just make sure you are going in a fairly straight line, at a steady speed. All tires should have traction (ie. not spinning/skidding)
Old 01-09-2005, 02:22 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: 1997 jimmy questions
Best to do it with NO throttle on at all.
Take you foot off of the gas during the switch.
TRust me, if you don't, the results could be expensive.
Old 01-09-2005, 05:31 PM
96JimmySLE 96JimmySLE is offline
As for your suspention, look in your glove box for the RPO codes. The ones like GU6 (3.42 gears) G80 (posi tracion rear end) FE9, FF, FF7, I belive deal with suspention. Increased capacity, smothe ride or you will know the ZR2, that was only offered on 2 dorr models. Tipe in GM RPO codes into google and you will be able to see what you have by thoes codes.
Old 01-10-2005, 09:47 AM
Thanks Brian, I will give it a shot.
Later,
Bob Shaw
