Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-19-2004, 04:07 PM
budylove68 budylove68 is offline
trim panels from 95-96 swap
Is it possible to swap the body trim from a 96 grand to a 95 bumpers included?
Old 12-19-2004, 04:12 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: trim panels from 95-96 swap
yes it is all the same, there is nothign different with the panels/trim from 95-98 and 93-94, but the 94 and ealier and the 95 and later the only difference was the mounting of the fog lights, 93/94 was mounted on the bumper, 95/later it was mounted into the bumper, so the bumpers would be diffferent between the 94 and 95/later models, but could still be swapped - just different placement of the fog lamps.
Old 12-19-2004, 04:17 PM
Thumbs up
Thank you much my friend, I want to get rid of the grey and but some painted ones I found.
Old 12-19-2004, 04:30 PM
ok ok I was lost at what you were referring to at first, you are talking about swapping the painted trim (from a limited model) for the plastic/grey trim (from a larado model). Yes, as far as I know this is possible, alto I have not done this, I do believe all the slide connection (points) are the same on both models.
Old 12-19-2004, 05:09 PM
Thanks, the grey is rather unsightly and I found a parted out grand (limited) that was the same color. The only catch is the front bumper that has an indentation for the larger grill on the 96.
