Old 12-19-2004, 02:51 PM
DDibbern DDibbern is offline
00 Blazer heater core nightmare
I can’t figure out how to get the heater box out. I removed one nut from the fire wall, 1 from in the cab and I broke two tabs that are on each side of this bolt. I can’t find another bolt anywhere but it appears that there is one more bolt left. I think it’s located towards the driver side of the box.
Old 12-21-2004, 10:33 PM
Re: 00 Blazer heater core nightmare
Help!!!!
Old 12-22-2004, 03:54 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Is the heater core leaking?
Did you buy a haynes or chiltons repair manual?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-22-2004, 08:26 AM
tom3 tom3 is offline
What I've heard on the newer Blazers you have to take the dash almost completely apart. Real tough job there.
Old 12-22-2004, 12:29 PM
I have the Chiltons which is nearly worthless...
It tells me to "remove heater core box"
It is leaking.
I already have the dash completely out.
Old 12-22-2004, 03:37 PM
NitrousPC NitrousPC is offline
You have to take the dashboard apart.
The final bolt is behind the glove box.
You will need to remove the radio to be able to reach behind it and shine a light in and you will probably have to use a 90degree socket behind the glove box from underneath to reach it.
Hope this helps.
NitrousPC
Old 12-23-2004, 12:01 AM
Might read through this info for the earlier models. Dash is somewhat different but the heater may be pretty much the same. http://www.sytyarchives.com/howto/vi...imate_controls
