Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-19-2004, 02:50 PM
pbow pbow is offline
alternator
i have a 95 rodeo 3.2 L . seems to have same problem as many of the other posts i have read, brake , battery lights on and the a/c blower wont run. The volt meter was also showing only about 11 volts so i pulled the alternator and had it checked. it checked out ok. I put the unit back on the vehicle ,the first time i started it all the trouble lights went off and voltage at the battery was 14.34 volts. After i killed the engine and restarted it all the trouble lights came back on and only have 12.6 volts at battery.
Paul
Old 12-19-2004, 07:37 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: alternator
Check/clean all of your ground points
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 12-20-2004, 01:35 AM
texan63 texan63 is offline
This same exact thing happened to me. I took it in and got the altenator rebuilt. I suggest not getting a new altenator but instead getting yours rebuilt. Luckily I walked away only paying $58. Mine had the same exact problems yours is showing and after the rebuild, a couple months ago, it has been running like a champ.
Good Luck!
Old 12-20-2004, 08:29 PM
thanx for the help guys
Old 12-21-2004, 10:23 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Re: alternator
replace your charge relay
check wiring to alt. and battery
if it still acts up stick in a new alt. bench testing an alt. is about 50% accurate
