Old 12-19-2004, 02:04 PM
dunmar dunmar is offline
throttle position sensor
Why does my throttle position sensor reading low voltage? I just replaced it two weeks ago.
Old 12-19-2004, 02:24 PM
sracing's Avatar
sracing sracing is offline
Re: throttle position sensor
??? The TPS doesn''t develop any voltage. It is just a potentiometer. Your ECM sends 5 Volts to it. (usually) One side of the TPS has this 5 Volts on it. The other side goes to signal ground (0 volts). The middle is the TPS voltage. It should go from ~0 volts to ~5 volts as you move the throttle.
So does it read low at closed throttle or full throttle?
Jim
SR Racing
Old 12-20-2004, 12:38 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
year/model/make?
or is this a code? was the code cleared after replacement? do you have a multimeter.
Old 12-20-2004, 10:32 AM
Re: Re: throttle position sensor
Originally Posted by sierrap615
year/model/make?
The code was cleared after the new one was put in.
It is a 1991 Pontiac Grand Am.
Old 12-21-2004, 12:17 AM
a poor connection or a bad wire is possible, the new TPS may be bad but not likey.
Old 12-21-2004, 04:07 AM
383PhoenixAm's Avatar
383PhoenixAm 383PhoenixAm is offline
Send a message via AIM to 383PhoenixAm Send a message via MSN to 383PhoenixAm
Well, depending on the application it could be calibrated wrong. I know on some cars the sensor will have too high or low a voltage if it is not set at a constant 5.14v (I believe) closed.
