| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
Questions about CSC
I messed up a paint job and im using castrol super clean as a remover like many people sudgested. how long should i leave it in the cleaner? also after can i strain it and use it for a different car?
"You can go far with a smile, but you can go farther with a smile and a flamethrower" Keep it Wingless.....
Re: Questions about CSC
CSC works very little on Tamiya paints. It works very well for stripping Testors and also stripping chrome parts.
You'll need alcohol or brake fluid to strip Tamiya in a timely fashion. For stripping Testors I usually give it a day, pull it out and hit the model with the back side of a sponge. Most of the paint should come right off. Chrome parts will strip totally, without needing to scrub, in less than 4 hours.
nightmaR3Z |
i just found out using DOT 3 brake fluid in the cold doesn't work as well.....it gets quite viscus. but in warmer temperatures it should be off in 2 or 3 hours or less, or it will be dissolved enough that you can just wipe it off.
take note, when i tried to strip something that was puttied the putty disolved. not sure if this is your case but i just wanted to add that.
http://www.automotiveforums.com/vbul...d.php?t=620111 ![]() "Look as far as the eye can see, go there, then look farther." |
Re: Re: Questions about CSC
CSC was pretty slow for me. I found that DOT3 is the best by far. DOT 3 worked better for me than Isopropyl Alcohol also
its acually crappy rustoleum paint, i dont know why i used it!!! will the CSC affect parts glued on?
