Hi all,
I just picked up a 2001 740 for a winter beater. I love the car but have a couple of questions: 1-The rear speakers (just the subwoofers or low frequency drivers) are not working. Where do I start to look? I don't think it is the connection, because the mid/highs work, unless there is a separate line for the subs. Is there an amp/x-over somewhere? Where should I start? 2-While I'm not complaining, the "Accept" nag doesn't come on with my nav. How could that be? Maybe the previous owner installed the no nag chip? Could there be another reason? I don't think he would have left the Valentine interface (which defeats the nav) in the car. Thanks |
There is a separate amp. On my '93 it's in the trunk, either behind the trim panel that separates the trunk/passenger compartments or up under the parcel shelf with the rear speakers-can't remember which.
Don't anything about the Nav. system. |
Re: Rear speakers
Thanks. I'll have a look for it. Might be the x-over or low end if it's bi-amped.
2001 740s have 1 - 14 channel amp in the trunk behind the CD changer. AMP has all crossover points also, there are multiple connectors for the speakers, but if one of the connectors had rattled loose you would have also lost some of your other speakers seeing they put multiple speakers per connector.
Not sure on where to tell you to start, sounds like the amp is fried. Cost at dealership will be around $2000.00. And you cannot just add a diff amp for the subs seeing that the input for the stock amp is balanced line 2 channel, the amp handles everything from volume control to crossover points. If you want to upgrade and replace the amp there is a way, but it is not easy. http://www.cardomain.com/memberpage/652272/3 There is a place to start. |
Re: Rear speakers
I'm in the audio/video field (pro gear), so I understand the concepts. If it does take balanced outputs this just means that the signal lines do not share a common ground with anything else. It's simple enought to know (if wired according to industry standards), what the 3 conductors are. With 14 outputs I doubt that they put more than one speaker per connector, unless it is simply to gang a couple of drivers together. Likely there are 7 left channel and 7 right channel inputs for each speaker type. Once I confirm the speaker connections I should be able to isolate the subs (left/right or maybe they are a mono sub). From there I can see if the problem is with the connection, driver, or amp. If it's the amp it would be quite simple to add a separare amp for the subs. Interfaces will accept line lever or powered inputs. If the output is non-existent than it is also simple enough to split off the signal from the main input and set a relative level which will then be adjusted from the overall gain (which must still be controlled from the head unit). There is probably a control signal from the head unit for all the dsp settings (maybe a DMX type protocol), but I really doubt that moved every single audio control to the amp (of course, I could be wrong). The only nightmare scenario would be that all signal arrive from the head unit at a fixed level, and all the controlls including volume are located in the amp/dsp. It's possible but highly unlikely that they took all the circuitry out of the head unit. It would be very expensive to make the volume control a digital potentiometer and send all the control signals to the amp. But, maybe they did. Anyway, I really appreciate your help in giving me an overview and where to start. If you are interested, I will post my findings with, presumably, more detailed technical information. Thanks for your response. Cheers |
Re: Re: Rear speakers
There are three connectors on the DSP/AMP mopdule and one of them is for the 4 subs located in the rear shelf. Here is a pinout of the connectors with wire colors so you can troubleshoot these outputs wiht a voltmeter or a spare speaker if you have one. X18771: 15pin Pin / Color 1 / Yellow 2 / Blue/Red 3 / YEllow/Violet 4 / White 5 / Blue/Gray 6 / Brown 7 / Blue/Brown 8 / Red/Green 9 / Brown 10 / Blue/Brown 11 / Yellow/Gray 12 / Blue/Violet 13 / Blue 14 / Blue/White 15 / Brown X18772: 18 pin 1 / Not used 2 / Black/Brown 3 / Not used 4 / Not used 5 / White/Yellow/Gray 6 / Not used 7 / not used 8 / Brown/Orange 9 / Brown/Orange 10 / Not used 11 / Black/White 12 / Not used 13 / White/Brown 14 / Not used 15 / White/Green 16 / Not used 17 / Blue/Red 18 / Yellow/Red X18773: 26pin 1 / Yellow/Red 2 / Yellow/Brown 3 / Not used 4 / Blue/Brown 5 / Yellow/White 6 / Not used 7 / Not used 8 / Not used 9 / Blue/White 10 / Yellow/Brown 11 / Blue/Black 12 / Blue/Green 13 / Blue/Red 14 / Yellow/Green 15 / Yellow/Brown 16 / Yellow/Gray 17 / Not used 18 / Not used 19 / Yellow/Black 20 / Not used 21 / Not used 22 / Not used 23 / Not used 24 / Blue/Gray 25 / Blue/Brown 26 / Blue/Brown
Well to give you the bad news first, the output of the reciever/tuner unit in the trunk is a fixed level to the amp and is only 2 channels. The amp also takes the spif output from the CD changer. Seeing that the amp is on the I-Bus the reciever/tuner can sence what amp is attached from the factory. The good news is once you remove the amp from the I-Bus the reciever/tuner changes the output to a variable 4 channel, this also removes the DSP option on the nav screen. The other problem is you will need a cable from the CD changer to the reciever/tuner seeing that you removed the amp and the CD changer cable that went to the amp. I have the part number if you go this route (they ordered 100 from Germany when i was working on my car seeing that there were zero in the states). Let me know, and good luck. |
http://forums.bimmerforums.com/forum...d.php?t=259519
This might be a better forum to get some answers about the sytem in the car. |
Re: Re: Re: Rear speakers
[quote=jcarey]Tom,
There are three connectors on the DSP/AMP mopdule and one of them is for the 4 subs located in the rear shelf. Here is a pinout of the connectors with wire colors so you can troubleshoot these outputs wiht a voltmeter or a spare speaker if you have one. <snip> Absolutely brilliant! Thank you so much. This is exactly what I needed. Thanks. |
