Old 12-19-2004, 12:13 PM
Iluvmytsi Iluvmytsi is offline
Idle Air Simulator?
I was looking around on dsmtrader.com, and saw a product called an Idle Air Simulator. You can see it on www.hesspower.com. Apparently its supposed to correct all bov venting problems without using a gm maf system. It tricks you computer into thinking that more air is in your engine i guess. What do you guys think of this, is it a scam or will it really work. The price is only $90 shipped which is pretty good considering a gm maf and translator is like $275. Let me know what you think?????
Old 12-19-2004, 12:45 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Idle Air Simulator?
unless it has a way to sense when the bov is open it is a scam. IF, it measures the amount of air coming out the bov then it could theoriticly use that to correct the MAS reading, but its probably a scam
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-22-2004, 02:55 PM
kjewer1 kjewer1 is offline
AF - Advisor
I highly doubt that anything Wess Hess offers is an outright scam. Doesn't mean its a superb product, but it wont be a scam. Long time DSMer, very trustworthy.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
