Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 12-19-2004, 11:27 AM
J_ROC812004 J_ROC812004 is offline
Send a message via Yahoo to J_ROC812004
Exclamation heater 94 t-bird
man it is like 0 degrees out side and my heater only blows cold air i don't know if it would be a sensor; a blendor door; or a heater core. the thermostat is good because the top hose was hot and my gauge went up like normal. and i am tired of driving it and being freezing cold plus i have a daughter i need to keep warm.
Old 12-19-2004, 05:45 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: heater 94 t-bird
A quick test. With the engine at normal operating temperature, temp dial set to hottest and the blower off feel both heater hoses. They should be about the same temp. If one is colder it indicates a blocked heater core.
Old 12-20-2004, 04:21 PM
k thank you for the help but what if they are around the same temp?
Old 12-20-2004, 05:16 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
You might still be low on coolant. Not low enough to affect the temp sensor, but low enough you are not pushing coolant through the heater core.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
If they are they same then it is probably a bad controller.
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
Old 12-20-2004, 05:20 PM
i have cheched coolant and i have enough
Old 12-20-2004, 05:22 PM
hey muscle is that your car where did u get the hood?
Old 12-20-2004, 05:59 PM
97Bird's Avatar
Do you have manual A/C Heater or Automatic Temperature Control and are both of the hoses I asked you about the same temperature or not?
Old 12-20-2004, 06:09 PM
i haven't had a chance to check the hoses but i have automatic climate control i know the top hose gets pretty warm when warmed up
Old 12-20-2004, 06:48 PM
97Bird's Avatar
I'm not talking about the radiator hoses which I think you are when you say the top hose is getting hot.
Old 12-20-2004, 07:30 PM
which hoses are u talkking about
Old 12-20-2004, 07:31 PM
i checked the radiater hoses and they are both warm
Old 12-21-2004, 12:11 PM
allright i checked bothe of the heater hoses and the are both the same heat
Old 12-21-2004, 03:49 PM
97Bird's Avatar
I don't know if a '95 has a self test or not but try this: Position the blower control knob at AUTO and the Function Selector knob to either PANEL or FLOOR. Then press and release the COOL and OUTSIDE TEMP buttons simultaneously and, within 2 sec, press and release the WARM button. The display should a tracer segment going in a counterclockwise direction during the self test. At the end of the self test trouble codes will be displayed. If there are no faults the whole display will illuminate. To exit the self test press the COOL button. Leave the ignition on at least 30 sec after you exit the self test so that the system can recalibrate itself. Let me know what code numbers show up. Your only problem now is the inside temp of the car MUST be between 50-90 degrees F for the test to work. I hope you have a heated garage or that it warms up soon!
Old 12-22-2004, 12:41 AM
I dont see that happening, on a warm day or a warm garage.
