Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 12-19-2004, 10:57 AM
cawhidde cawhidde is offline
Unhappy dodge daykota
We have a 94 dodge daykota, we put a new motor in it. The question is this motor is from a 2000 daykota, will it work? The motor is in but won't start! Does the brain have to be reset? Thank You
Old 12-22-2004, 02:25 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: dodge daykota
Depending on what motor it is, (3.9 V6 or 5.2 V8) It sounds like something simple as the crank sensor that mounts between the bellhousing and the back of the motor on the passenger side. Before you check that, make sure you have fuel, and spark.
Old 12-23-2004, 05:21 AM
Re: Re: dodge daykota
Can you Please tell me where this 3 prong plugs in at? It comes off the distributor and goes where? The bottom half has been switched out, the top half is the same and the wiring harness is the same. The diagram is of no help! It's like looking at a street map of Japan.LOL I have 6 prongs open and cannot find any place to plug them in at! I understand not all of them need to be pluggeg in, but I am sure this one needs to be. Should we unplug everything from harness and start over? Please help us.
Old 12-23-2004, 10:09 AM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: dodge daykota
Did you swap a six for an eight or what?
My Mopars
Old 12-23-2004, 01:21 PM
No, everything is the same just the block was warped and switched out. When we went to plug everything back in we ended up with a mess!!!! Just want to know where to plug in the connector that comes off of the distributor? Thanks
Old 12-23-2004, 02:29 PM
BleedDodge's Avatar
Re: dodge daykota
You still didn't tell us what engine you have in there. Is this a four cylinder?
My Mopars
Old 12-23-2004, 03:33 PM
No, 94 dakota 3.9 6 cyl. ? Where does the one coming off of distributor and bell housing plug into because we can't find those! Thank You
Old 12-29-2004, 02:56 AM
BleedDodge's Avatar
Re: dodge daykota
They go back into where you unplugged them from when the old motor was still in there.
My Mopars
Old 12-29-2004, 08:17 AM
O.K. I believe we found them. thanks
We have spark going into coil, but no power coming out. Truck started before engine switch out. Can't belive the coil would be bad! Any ideas would be great. Thanks for all your help
Old 01-02-2005, 02:00 AM
Re: dodge daykota
when you say spark, do you mean, you have 12 volts going to the coil or what? While you're at it, let us know if you have fuel, spark, or neither.
