Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 12-19-2004, 10:53 AM
ranger1994 ranger1994 is offline
Brake Light Problem in My 1994 Ford Ranger
Hello Everyone,
I recently had my annual vehicle inspection on my 1994 Ford Ranger. The inspectors discovered that all of the lights work properly, with the exception of my brake lights. When the brakes are applied, the brake lights do not illuminate. All the fuses were checked, all the lights were replaced, and still the brake lights do not illuminate. Does anyone out there have a possible solution.
Thank you in advance,
Ned
Old 12-19-2004, 05:49 PM
graphicassult's Avatar
graphicassult graphicassult is offline
Send a message via AIM to graphicassult Send a message via Yahoo to graphicassult
Re: Brake Light Problem in My 1994 Ford Ranger
well its obviously going to be a wiring problem then if all of that was checked and was fine. The fun part is finding your wiring problem.
"All right Ramblers, let's get ramblin."
Old 12-31-2004, 08:40 AM
ranger04 ranger04 is offline
Originally Posted by ranger1994
Hello Everyone,
Ned
Before you go through the headache of trying to trace a wiring problem, you may want to check the brake pedal switch under the dash first.
Old 01-02-2005, 08:19 PM
110578 110578 is offline
Send a message via AIM to 110578
The Brake light switch is behind the brake pedal. It a small toggle that the brake pedal presses against to complete a ciruit to the brake lights. That sounds to be what your problem will be.
Old 01-09-2005, 11:55 AM
Re: Re: Brake Light Problem in My 1994 Ford Ranger
Thank you very much. It was the brake light switch.
Old 01-09-2005, 11:57 AM
ranger1994
