Old 12-19-2004, 04:25 AM
DJ_Inevitable's Avatar
DJ_Inevitable DJ_Inevitable is offline
Wierd Battery Problem
I just replaced the alt, but while i am driving down the road, my battery light will come on, then go off, at random. then tonight i was coming home from the bar, and the light stayed on... and my car finally cut out and would not start... could this be that my battery is no good, or what? it is really starting to piss me off, and it only started to do it recently...
Old 12-19-2004, 11:03 AM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Re: Wierd Battery Problem
Where did you get the alternator?? Sounds like you got a bad one, I'd have your battery and alt checked.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 12-19-2004, 06:22 PM
i got it from autozone, tomorrow i'm off work, so i am going back there to have them check it, and i might just return it for a new one... i have a one year warranty ... thanks for the help.
Old 12-19-2004, 07:50 PM
2ndb18's Avatar
2ndb18 2ndb18 is offline
Send a message via AIM to 2ndb18
Well check your battery then check your charging system and then youll know the problem
88 civic dx
Old 12-19-2004, 08:44 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
i would try and get a higher warranty alternator man. usually 1 years are rebuilt and are junk. i know at my work our 1 years never lasted a month. they have been downgraded to a 90 day warranty now cuz there so shitty. IMO spend the few extra bucks and get a brand new one with a higher warranty if u can afford it
also, it is a good idea to get ur battery checked. it might be fine tho because the battery is used for starting the car only. after that it is run off the alternator. a good way to check if ur alts dead is start the car, then remove the negative cable on the battery if ur car dies, alts shot, if it stays running, its fine
Old 12-20-2004, 09:57 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
if your battery light comes on while you are driving...your alternator is bad...or is not hooked up properly.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 12-20-2004, 05:51 PM
yeah, bad alternator... took it back today and got a new one. got to love warrenties!! and everything is working good. now i can can put my system back in.
Old 12-20-2004, 10:53 PM
badboyzkustumz badboyzkustumz is offline
Send a message via AIM to badboyzkustumz Send a message via Yahoo to badboyzkustumz
if youve got a system, even if its just an upgraded head unit you should invest in a higher amp alternator. the stock 60 just wont cut it specially if its a rebuilt. trust me i know. blew thru 4 of em in less than 3 months.
Old 12-21-2004, 03:48 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Pop your dizzy cap and check to see if you fried your coil. Same exact thing happened to me, even after putting an MSD ignition system with external coil (MSD blaster II). It's definitely the alt. I haven't had the time or money to replace the alt yet, so while I'm driving on the freeway, I drop into neutral and let the car idle every minute or so, for some reason, this won't over-charge the coil and allows me to keep driving without the engine light coming on... If the engine light comes on, I turn the car off, and re-start it. Pain in the ass for sure, but it works.
