Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-19-2004, 02:43 AM
TreeFrog's Avatar
TreeFrog TreeFrog is offline
Send a message via AIM to TreeFrog
how to raise a coilover suspension? need a swayer tool?
i'm trying to get my car raised for winter. i have KYB GR2 gas shocks, and a Skunk2 coilover kit. A shop said they could raise it to stock height and all i needed was some "swayer tool" they described it as a wrench with teeth. i've been looking for one, but can't find one. so far only tried autozone. don't have time for a wild goose chase. anyone have any ideas?
Something new is coming...
Old 12-19-2004, 08:32 AM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
I'm pretty sure what you need isn't a swayer tool... it is actually called a "spanner wrench" sp? I'm not sure where to get one but they are used on things such as CNC machines and suspension.......
If you put the skunk2's in you should have the wrench.....
http://cgi.ebay.com/ebaymotors/ws/eB...category=43989
looks like these... some have the pivot head for varying sizes and some are solid for one size use...................
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 12-19-2004, 10:32 PM
TreeFrog's Avatar
Re: how to raise a coilover suspension? need a swayer tool?
i didn't install the suspension, i bought the car with it. i just need to raise the car up for winter ASAP because its slamed and i need to be able to get around, lots of snow here. i don't want to hit an ice chunk on the highway and crack my front bumber.
Old 12-19-2004, 10:52 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
call skunk2 and ask questions....usually the ride hight is adjusted by the springs (coil overs) not the shocks...
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 12-20-2004, 06:15 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
you can probably order a spanner wrench from skunk. or you can check napa, or call snap-on im sure they'll have one
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-23-2004, 10:42 AM
kjewer1 kjewer1 is offline
AF - Advisor
Sometimes you have to make sure you are not over looking the obvious. I turn them with my hand
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 12-24-2004, 03:33 PM
TreeFrog's Avatar
the shop said they needed a tool, still can't figure out what i need or where to get it
