Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-18-2004, 11:38 PM
Automobile Maniac's Avatar
Automobile Maniac Automobile Maniac is offline
Weld hole in oil return pipe?
The arrow points to a little hole that makes my 1G lose 1 quart of oil in about an hour. Question is--after I soak the pipe in gasoline to clean out the oil and carbon, can/should I just dab a little JB Weld paste onto the hole? or weld it with a torch? I really don't want to buy a new one.
Thanks
Old 12-19-2004, 05:22 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
tig welding it would proably be alot better
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 12-19-2004, 05:54 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: Weld hole in oil return pipe?
its such a cheap item , i would replace it ....
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 12-19-2004, 08:04 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
is this the turbo oil return line? if it is you should definately just replace it with a new one since if you restrict the flow at all when you weld it you could end up seizing your turbo from not having enough oil flow.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-22-2004, 12:37 PM
riff22 riff22 is offline
mine had a hole and my dad used silver soder and i havent had a problem with it since. is a tig for aluminum?
Old 12-22-2004, 01:17 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: Re: Weld hole in oil return pipe?
70+ from a local dealer.
Find one in a pick and pull.
Kris
2012 Genesis Coupe 2.0t
