Old 12-18-2004, 07:34 PM
j13jjs j13jjs is offline
Transmission Problems
I just picked up my 99' Spyder GS-T, I am noticing some roughness in the shifting, a lot of times I have to double clutch, not sure why. Also sometimes once the car is already running and I am at a complete stop and try to put it in reverse it grinds when I go for it, so I have to roll forward a little bit then try again? Am I doing something wrong? or should I take it somewhere?
Old 12-18-2004, 11:19 PM
coolguycooz coolguycooz is offline
Try replacing the gear box oil. Your clutch could also be bad? And about the griding your gear if your rolling a littla already while your trying to put it in to reverse it will do that. Try stopping on a flat road then try to put it in reverse if it still does that im not sure.
Old 12-19-2004, 12:27 AM
Re: Transmission Problems
thanks, Im going to get the oil changed monday anyways so I can have them swap out the gear box fluid also, anyone else have any ideas?
Old 12-19-2004, 12:30 AM
pro3racer pro3racer is offline
Whats the best oil for a manual tranny? I heard synthetic tranny oil is actually not good. Should i go the dodge dealer and buy the mpar factory oil, or is there something better? I was wondering if lucas oil had anything good, i like there stuff
1991 Eagle Talon ESI, manual, 2.0 FWD
1992 Eagle Talon TSI, manual, 2.0 FWD
Old 12-19-2004, 12:33 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
BG Synchroshift is one of the best gear oils to use. You can use 75-90 weight. You can get GL5 from walmart or some other store for cheap but after time it has an additive that corrodes the brass synchros. GL4 is the good stuff but it is expensive and can only be bought at the dealership. Very expensive if you have them change it.
Lucas Gear oil is awesome, I use it in my tranny and you can either run it straight or mix it with another tranny fluid.
Old 12-19-2004, 09:10 AM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
Lucas is thick as hell that what someone told me to put in my motor oil to try and pusy my lifter back up before i threw a rod
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 12-19-2004, 12:38 PM
EclipseRST's Avatar
Banned
Yes you can run lucas in your engine to but they make specific oil for that. You also wouldnt want to run a lot of it just because it is thick and it would be harder to go through all the little oil ports and the turbo.
Old 12-19-2004, 04:26 PM
xavier3jr's Avatar
yea it was Lucas oil stabilizer or something like that i just put a quart in it and i dont have a turbo :-(
Old 12-19-2004, 08:29 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
yeah i ruined 2 engines because of that lucas oil stabilizer. it's too thick that it can't get up to the head and it melted my camshafts right to the head, TWICE! i'm never using that shit again.
95 Talon TSI AWD
97 Eclipse GST
Old 12-19-2004, 08:44 PM
EclipseRST's Avatar
Banned
You were probably using the wrong stuff... They have certain thicknesses for certain oil applications. I use it, and have in all of my cars and have never had a problem with it. Make sure you mix it correctly and are using the right weight oil for your application.
Old 12-19-2004, 08:49 PM
no it was the oil stablilizer stuff. i think it's just too think for our cars or maybe i was mixing too much but oh well, i'm done using that stuff now.
95 Talon TSI AWD
97 Eclipse GST
Old 12-19-2004, 09:08 PM
xavier3jr's Avatar
i put 1 quart of it in with 10w-30 and it made my car run fine for a while
