Old 12-18-2004, 06:06 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
blow by question
well looks like i have blow by in cylinder 3...would it hurt my motor if i am spraying a 50 shot on the d16a6?
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 12-18-2004, 06:08 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: blow by question
Well spraying on a rock solid stock motor is risky, so its expecially risky if your spraying on a motor that needs a rebuild.
Old 12-18-2004, 06:12 PM
it was just rebuilt somehow ook like the ring didnt seal right on cylinder 3....i just wondering if blow by really affects the car much?
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 12-18-2004, 08:53 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
what is blow by?
and how do u fix it?
Old 12-18-2004, 09:07 PM
Forunn Daberator
blowby happens when your rings are worn, cylinder walls are worn, rings arnt seated properly, ect. It is exactly what it sounds like, its when air/fuel mixture escapes past the piston on the compression/exhast stroke and when oil escapes past the piston the other direction on intake/power stroke.
Textbook definatition is: Blowby: The unburned fuel and and products of combustion that leak past the piston rings and into the crankcase during the last part of the combustion stroke.
Potentially you could literaly blow your motor into pieces if nitrous/fuel escape past the rings and into the crank case and ignite.
