Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-18-2004, 04:34 PM
skyllz skyllz is offline
Angry Help me diagnose the problem!! (valve seals?)
My car is burning oil, when its fully warm (at half) and I press on the throttle I get blue smoke, its not very blue but you can definitely notice it. At idle is not too bad but its a bit less blue (still blue though) Also my oil consumption is quite bad, every two weeks I've got to add about a half litre of oil. Cars got 180 straight compression and the spark plugs are not fouled at all. I don't recognize any loss in power, my 2nd gear has also been the fastest and still is. The tip of my exhaust has a lot of oil on it which is obviously not normal.
Also forgot to mention, the car starts very well, I turn the key and it starts like a pro very little crank needed even in the cold weather no misfiring!
Would the valve seals be toast? Do I need a valve job done? I am hoping its not the rings! ahh.. car has 88000 miles and is a NON-TURBO 1995.
Old 12-19-2004, 11:46 PM
spanky9929 spanky9929 is offline
Send a message via AIM to spanky9929
Re: Help me diagnose the problem!! (valve seals?)
sounds like valve seals to me i got the same problem with my car i pulled the engine and found out it wasn't valve seals it was the oil rings on the piston but if u did the compression test and it was fine then its got to be the valve seals
Old 12-20-2004, 08:33 PM
pr0's Avatar
pr0 pr0 is offline
spanky9929 did you have oil fouled spark plugs? Would the oil rings reduce the compression?
Old 12-23-2004, 02:21 PM
joemathews's Avatar
joemathews joemathews is offline
If you have bad rings, yes, your compression will be poor. Most likely valve seals--I'm about to take care of the same problem in my car.
1996 Eagle Talon
