Old 12-18-2004, 04:22 PM
Knixon71 Knixon71 is offline
Speakers in front doors
Hey all,
Just curious how to get the front doors off (2000 GMC Sierra 4x4 Z71) to access the speakers. I haven't really tried yet, but I am limited in my time to work on my pickup so I would like to go into the project with some knowledge rather then spend a couple hours trying to figure it out. I have at least one blown speaker from the moron who owned my pickup last and want to replace them both as it sucks not having loud enough front speakers to match my subs.
Thanks
Old 12-18-2004, 05:41 PM
03-Silverado 03-Silverado is offline
Re: Speakers in front doors
I believe you have 6 1/2" speakers with basic tweeters
My 2003 Silverado LS
Current Mods...
Flowmaster Series 40 Dual Exhaust Going Out The Rear
Navigation System / Competition Car Audio
*AM/FM/CD/MP3/DVD/TV/GPS/PS2 Navigation System*
Viper Remote Engine Start System
Hypertech Programming
K&N Cold Air Intake
***Top Speed 128 MPH***
Future Mods...
7" Suspension Lift, 3" Body Lift w/ 35" rims and tires
Performance MAF sensor
Throttle Body Spacer
Old 12-18-2004, 05:48 PM
6 3/4 components. Probably gonna replace with some MB Quarts.
Old 12-18-2004, 08:35 PM
buttnekked buttnekked is offline
most 6 1/2's have an over siazed ring for 6 3/4 also.
Old 12-18-2004, 09:54 PM
I HIGHLY recommend that you stick with MB Quarts for all your speakers. I have the 6 1/2" MB Quart component system with crossovers in the front and 4 1/2" MB Quart component system with crossovers in the rear and they sound AWESOME!!!!
Current Mods...
K&N Cold Air Intake
Future Mods...
Old 12-27-2004, 07:59 PM
wrench83 wrench83 is offline
well howdy
The front door pannels are not hard to do it just takes some guts untill you here that first pop of the tabs pulling out of the door. two screws and some quick tabs and the door pannel lifts right up out of the window track. I recomend getting a door panel poping tool from your local auto parts store it's cheep and will give you some confidence.
Once the pannel is off the speakers are just quick cliped in for easy removal.
Good Luck.
Old 12-31-2004, 12:37 PM
Thanks wrench.
Another question, how do you access the rear speakers (four door model)? I have taken off the screw in the cup holder and the one in the door handle and cannot figure out how to get to that thing. The grill looks like the front where the clips are bent over the door so you have to get to it from the back.
Let me know.
Thanks
Old 12-31-2004, 10:32 PM
same setup; take out the screws then pop the trim clips around the edge. Then panel should come right off.
Old 01-03-2005, 06:45 AM
Nigel215's Avatar
Nigel215 Nigel215 is offline
The rear door has a bunch of clips you have to pop off. I just used a rag and a flathead screwdriver. The whole door panel comes off, not just the speaker grille.
2000 Silverado LS 4.8, K&N FIPK, Gibson Extreme Dual Exhaust, Line-X Bedliner, Black Speed Grille, Viper Alarm System, Custom Audio system.... (need to update my pic)
Old 01-05-2005, 02:16 PM
mallen810 mallen810 is offline
Re: Re: Speakers in front doors
Where can I get the MB Quartz
Old 01-05-2005, 02:20 PM
Go to this website and put in your zip code:
http://www.mbquart.com/2003/en_US/dealers/
Old 01-05-2005, 03:06 PM
do you know the model number for speakers
Old 01-05-2005, 03:11 PM
Nah, but if you go to:
www.crutchfield.com
They will tell you what fits your car and have loads of research tools. If you have a 1999 (new body) and up chevy/GMC then the front is a 6 3/4 components (but down to 6 fits) and 4x6 in the rear doors.
Old 01-21-2005, 04:08 PM
how much trouble to take out back speakers and how do you get the one on the drivers side. did my front speakers today with no problem. was going to do back but wasnt sure.
mike
Old 01-22-2005, 02:35 PM
Nigel215's Avatar
the rear speakers were a little bit of a pain... Mostly because I have a 3 door... The one rear door all you do is take out the 2 screws in the cupholders, then you have to pop off the whole door panel. Just start at the door jam with a flat head, all you do is pry them off , you will hear them pop, and they are about every 12 inches. Now the drivers side, you have to take out the rear seat, look under the sear next to the jack on thet little shelf, their are 2 bolts their, and on the drivers side they are on the floor, not hard to find. Just undo thoes 4 bolts and lift the seat out.
Now the driverside panel, take out the same screws out of the cupholders...its basicly the same as the passenger side, but its the whole panel, all the way to the rear window. You will need to disconnect the seatbelt too. To get everything back in , just get everything lined up and push till you hear them snap in.
let me know if you have anymore questions or if i left anything out.
