Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 12-18-2004, 04:21 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Did I Fry my Deck??
Alright, i was putting a mono amp on my rear speakers and there was only one frequency playing. My friend Andrew was helping me and when i suggested putting the amp to the side coming from the deck, he agreed and we hooked it up. We started the radio and turned on the amp, all of a sudden the fireworks started. The two 15 amp fuses blew on the amp....WEEEEEE! Then we disconnected the RCA cable, the REM wire and took the amp out of the car. The speakers were all hooked up again and when i tried to play the music.....nothin! The LCD screen still plays and the volume goes up, but no music. We had the deck turned to the rear channel and it is a 4 channel deck. It is a $675 deck w/ an LCD screen and don't want to blow it, but want to know...did I??? Someone please help!!
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 12-19-2004, 09:41 AM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
Wait a minute? You put the Amp Out wires, that are supposed to go to the speakers, and connected them to the head unit's Out wires, that are also supposed to go to speakers....?
If that's the case... yeah, you probably f*cked up your head unit pretty good!
Honda Enthusiast
Old 12-19-2004, 09:51 AM
Schister66's Avatar
AF -Advisor
Re: Did I Fry my Deck??
Yeah, my friend was trying diff possibilities to try make it sound better and when he did that, it blew the fuses on the amp and probably the ones on my deck as well. Everybody i've asked said that i probably fried the amp inside the deck. If that's the case, i have a friend named Scott that can rebuild it for nothin....provided its fixable.
Old 12-22-2004, 07:47 AM
Wister06 Wister06 is offline
Send a message via AIM to Wister06
when the fireworks usually start u most likly blew the preamp in your unit i would recommend calling the company and finding out what it'll cost to get a new 1 and to have your friend put it in!!!! good luck!!!
Old 12-22-2004, 11:49 PM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
never trust a friend who has never done stereo installs... case and point.. read up on it yourself, or get an installer to do it.. yeah you basically created a huge short in the system, and fried your head unit, and possibly the amp as well. Even though the fuses went. only reason the display and CD player still work is because the preamp, and deck controls are different circuits.. the deck controls control that portion by going thru another system.. hence you still have display, and control function, but no sound.
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 12-30-2004, 07:13 PM
Schister66's Avatar
AF -Advisor
That's exactly what happened...i have function of everything, but no sound. Is that preamp a removeable part or not?? What do you think would be an approx. price. By the way Andrew does know how to install stuff, he was just lazy and tired that day and wanted it to work and in the midst of it he came up with the idea and wanted to try it...it was more my fault that i agreed. His amp still works too...jerk (Andrew).
Old 01-19-2005, 05:48 PM
riccimangan riccimangan is offline
well he fu*ked it up so make him pay for it,simple,.,.
oh and get a pro next time, it may cost more but it'll be worth it in the end,.,,.,.,.,.,.
Old 01-20-2005, 09:54 AM
94hondaacc 94hondaacc is offline
yeah its messed up. thats like putting a positive and negative together. the amp in the radio is screwed up, but you can probably do this.buy a four channel amp with a crossover to each channel for your door and rear deck speakers.and another amp for you subs. if you connect all your speakers to amps you wont need the radios speaker cables just the rca wires.i have a panasonic cq-vd7200 and i dont use the wires for the speakers cause i have amps to all of them. p.s. change your factiry speakers if your gonna but amps to them, and dont go get an amp with too much watts for the small speakers.
Old 01-20-2005, 01:00 PM
Schister66's Avatar
AF -Advisor
I was planning on getting an amp for my speakers...i don't have subs nor do i plan on getting any either. I should try that idea...it might just work. Oh, by the way, i already ditched the stock speakers...i have Alpine Type R 6x9's in the rear deck and Type S 6.25" in the front.
Old 01-20-2005, 02:16 PM
Good Choice, With The Right Amp Your Sounds Should Be Very Clear And Loud, Overall A Good Clean Sound. Good Luck Hope It Works.
Old 01-20-2005, 08:28 PM
Schister66's Avatar
AF -Advisor
The idea that 94hondaacc suggested sounds too good to be true...is it? Before i get my hopes up i want someone to verify this if possible. (no offense 94hondaacc I just don't want to get my hopes up w/o some other evidence)
Old 01-20-2005, 09:43 PM
yeah no doubt. hopefully someone can verify my story, or just borrow your friends amp and try it with a speaker. if your rcas still give signal you should ha ve sound trough your speaker via the amp. i had this happen to a pioneer deck that i had and the only way it worked was through the amp.i dont know if it will work on yours though, but good luck
Old 01-20-2005, 10:39 PM
Schister66's Avatar
AF -Advisor
Do you think that the RCAs will still work?? I believe you cuz i asked one of my friends and he said that should work. That's how you do speakers and subs to begin with.
Old 01-21-2005, 09:02 AM
I Think That It The Rcas Will Still Work, But Only One Way To Find Out. Try It And Let Me Know What Happened.
Old 01-21-2005, 02:47 PM
Schister66's Avatar
AF -Advisor
I have to wait until at least Monday to do it so there won't be any news on it soon.
