Go Back   Automotive Forums Car Chat > Jaguar > X-Type
Old 12-18-2004, 03:38 PM
flyguy7150 flyguy7150 is offline
changing brake pads in x-type
Hi im new here and i need some help. Has any here ever changed the pads in their xtype. I cant seem to push the hydraulic rod back. Its not like other cars. Can anyone help?
Old 02-16-2005, 04:28 PM
cobra73_nl's Avatar
cobra73_nl cobra73_nl is offline
Re: changing brake pads in x-type
You Have To Turn Them In With A Special Tool It Pushes And Turns The Cilinder Back Into The Caliper
Note That On The Rear The One Has To Be Turned Clockwise And The Other Counter Clockwise
Old 02-16-2005, 07:02 PM
Thanks for actually helping out but i figured it out a while ago
Old 01-28-2006, 01:23 PM
Jeremy02XType Jeremy02XType is offline
Does this apply only to the rear calipers or all 4? Also does Jag use a conventional ebrake setup or is it a drum inside the rotor hat ebrake assembly?
Old 01-29-2006, 04:07 PM
The rear ones are the only ones you have to turn. The fronts are like most cars
Old 01-30-2006, 08:19 AM
does it require a special tool or would vice grips work? also do the calipers require a hex nut to get them apart?
