Old 12-18-2004, 02:20 PM
buttnekked buttnekked is offline
Question Getting paint off plastic
Ok after much searching I'm still stumped. I bought a set of xenon fender flares on ebay and I need to remove the old paint from them. They were painted to match the vehicle unfortunately they didn't use any additive to keep the paint flexible. The current paint is cracked and peeling in sections so coating over it isn't an option, most strippers attack the plastic, I'm afraid sanding and sand blasting will mark the plastic, and it's just too cold here to try pressure washing.
Anyone got a tip or suggestion? All help is greatly appreciated.
Old 12-18-2004, 05:38 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: Getting paint off plastic
brake fluid....
just make sure you wash it GOOD before you paint them.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 12-18-2004, 08:34 PM
thanx hadn't thought of that. Bought some oven cleaner to try.
Old 12-19-2004, 12:46 PM
chuck16's Avatar
chuck16 chuck16 is offline
Or just paint thinner would work as well.
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 12-20-2004, 11:23 AM
slacker_53's Avatar
slacker_53 slacker_53 is offline
Re: Re: Getting paint off plastic
Paint thinner won't touch catalyzed paint.
-slacker
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
Old 12-23-2004, 01:10 PM
dcarson dcarson is offline
removing paint.
Try lacquer thinner. Take some old rags and wrap around flares and then soak rags in teh thinner so it stays on longer. Also try some of the commercial paint strippers. Try autobody.com I think is the web site. They sale paint remover that I have used on airplanes before. Spray the remover on, put in a room or garage at least 60 degrees, and the paint litterally just runs off.
Old 12-29-2004, 02:21 AM
emmitt69's Avatar
emmitt69 emmitt69 is offline
I'm curious now, what did you try useing and what worked best????? I'm into collision repair and painting and wanted to know.
Old 12-29-2004, 07:21 AM
paint removers
SEM makes a paint stripper made specifically for bumpers and plastic that will take off pretty much any paint out there except factory baked on enamel.
Kleanstrip makes a paint remover that it markets for aircraft which will bubble up about any paint and let you wipe it right off.
I will e-mail to get the exact name of the stuff we use to strip entire planes with and post it later.
Dwight
Old 12-30-2004, 09:52 PM
so far no luck. Oven cleaner won't touch automotive paint. Aircraft stripper (wal-mart) will attack the plastic. Thinner seems ineffective as well. Brake fluid will work but is messy and time consuming. The SEM product would seem to be the best idea; I'll have to research it. Sanding is always an option but again it's time consuming as well. I considered sand plasting but it has been too cold here to experiment.
